Ir reciever in an finite state machine
Greetings
fixed
Problem I need help with :
Every switch is depending on the value of the recieved Ir.code.
How do I it?
Currently using:
IRremote library API
Solution trial:
fixed
Question:
Is it fine to do it like that or is there a way smarter way ?
Other things:
If someone would check my other code I would be very thankful !
 fixed
In advance thank you for your help. Have a good day!
Yes - but what was the question?
Mark
If my solution would work if not what would work / is smarter.
Can't test my code right now.
Also does anyone know how long an ir code last if i send it with irsend.sendNEC(5,16) ?
Fixed
