Ir reciever module (is reciving but idk how to send signal)
i use below code to recive and send ir to turn on the tv, i use this module
i click ON/OFF button in tv remote and in serial i recive this :
Serial.println(results.value);   with value    326726612
now i try to pass that code to serial (so the module will send ir data and turn on the tv)
i recive mssage
Serial.print("Data sent via IR - (INT): "); with value 326726612
but nothing happen and tv is not starting
#include <IRremote.h>
#define IR_RECEIVER_PIN 19 // RX1 pin on the Arduino Mega
#define IR_TRANSMITTER_PIN 18 // TX1 pin on the Arduino Mega
IRrecv irReceiver(IR_RECEIVER_PIN);
IRsend irTransmitter(IR_TRANSMITTER_PIN);
decode_results results;
  irReceiver.enableIRIn();
  //IR RECIEVER
  if (irReceiver.decode(&results)) {
    // Print the received IR signal value
    Serial.print("Received value from ir reciever (INT): ");
    irReceiver.resume();
  //IR SEND
if (Serial.available()) {
  // Read the incoming data from the Serial interface
  String data = Serial.readStringUntil('\n');
  unsigned long value = strtoul(data.c_str(), NULL, 10);
  // Print the hex value that was sent via IR
  Serial.println(value);
  // Send the data via IR transmitter
  irTransmitter.sendNEC(value, 32);
Use hexadecimal representation in matters like this. Decimal representation is useless.
Please post a link to the datasheet. Sales site picture tells nothing.
Please post schematics.
i tried to convert in hex
Received value from IR receiver (HEX): 0x137973D4
but when i pass 0x137973D4 to serial nothing happen with tv
  // IR RECEIVER
    // Print the received IR signal value in HEX
    Serial.print("Received value from IR receiver (HEX): 0x");
    Serial.println(results.value, HEX);
    Serial.print("Protocol: ");
    Serial.println(results.decode_type);
  // IR SEND
    unsigned long value = strtoul(data.c_str(), NULL, 16); // Parse HEX number
    // Print the HEX value that was sent via IR
    Serial.print("Data sent via IR (HEX): 0x");
    Serial.println(value, HEX);
//    irTransmitter.sendNEC(value, 32);
    irTransmitter.sendNEC(value, 0x20);
Are the IR frequencies set to the same? I have a memory saying there is more then one kind of IR links.
