IR reciever
Hello, I wanted to control a IR reciever without a library. I looked at the IR library spescally the NEC protocol but could’t understand how it works. Could anyone explain me in basic language so I could write my own code. Thank you
See the parallel thread about using IR remote without library.
If you want to write just another IRremote library, you should know how to do that. If you don't, use the library.
If you are using one of the below then nothing else needed.
Outputs a digital signal.
https://www.ebay.com.au/itm/2pcs-IR-Infrared-Obstacle-Avoidance-Sensor-Module-for-Smart-Car-Robot-NT/202435840936?hash=item2f221dcba8:g:9WsAAOSwel5bkjtb
