ir reciver
I was trying to set up an ir receiver when this error message came up
In file included from ir_reviver.ino:1: /Users/lorenzo/Documents/Arduino/libraries/IRremote/IRremote.h:365: error: ISO C++ forbids initialization of member 'sendPin' /Users/lorenzo/Documents/Arduino/libraries/IRremote/IRremote.h:365: error: making 'sendPin' static
what does that mean???? :confused:
It's impossible to say unless you post the program that gave rise to the errors.
...R
this is the code
include "IRremote.h"
int receiver = 13; // Signal Pin of IR receiver to Arduino Digital Pin 11
/-----( Declare objects )-----/ IRrecv irrecv(receiver); // create instance of 'irrecv' decode_results results; // create instance of 'decode_results'
void setup() /----( SETUP: RUNS ONCE )----/ { Serial.begin(9600); Serial.println("IR Receiver Button Decode"); irrecv.enableIRIn(); // Start the receiver
}/--(end setup )---/
void loop() /----( LOOP: RUNS CONSTANTLY )----/ { if (irrecv.decode(&results)) // have we received an IR signal?
{ translateIR(); irrecv.resume(); // receive the next value } }/* --(end main loop )-- */
/-----( Function )-----/ void translateIR() // takes action based on IR code received
// describing Remote IR codes
switch(results.value)
case 0xFF629D: Serial.println(" FORWARD"); break; case 0xFF22DD: Serial.println(" LEFT"); break; case 0xFF02FD: Serial.println(" -OK-"); break; case 0xFFC23D: Serial.println(" RIGHT"); break; case 0xFFA857: Serial.println(" REVERSE"); break; case 0xFF6897: Serial.println(" 1"); break; case 0xFF9867: Serial.println(" 2"); break; case 0xFFB04F: Serial.println(" 3"); break; case 0xFF30CF: Serial.println(" 4"); break; case 0xFF18E7: Serial.println(" 5"); break; case 0xFF7A85: Serial.println(" 6"); break; case 0xFF10EF: Serial.println(" 7"); break; case 0xFF38C7: Serial.println(" 8"); break; case 0xFF5AA5: Serial.println(" 9"); break; case 0xFF42BD: Serial.println(" *"); break; case 0xFF4AB5: Serial.println(" 0"); break; case 0xFF52AD: Serial.println(" #"); break; case 0xFFFFFFFF: Serial.println(" REPEAT");break;
default: Serial.println(" other button ");
}// End Case
delay(500); // Do not get immediate repeat
From section 6 of Read this before posting a programming question:
Post your complete sketch (program code)! If you don’t you waste time while people ask you to do that.
When you post your code put it between
tags. You can do that by hitting the </> button above the posting area.
Post a link to the documentation for the IR library you are using.
...R
