IR Remote Bulldozer Bot
Hi, I need to now how to control this code with a remote. The remotes model number is AKB73715608 and the project is meant to work with the Make: It robotics remote, but i am trying to use my own tv remote. Any suggestions? I will post the code down below
Thanks,
Pat.
Code:
// * File Name : Bulldozer_IR_remote.ino
// * Author : RadioShack Corporation
// * Version : V1.0
// * Date : 2014/01/22
// * Description : Use the RadioShack Make: it Robotics Remote Control to control the bulldozer robot.
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, see Licenses - GNU Project - Free Software Foundation
Press the following buttons (SW) to control the robot.
SW1 forward
SW3 backward
SW4 turn right
SW2 turn left
SW5 blade up
SW6 blade down
#include <MakeItRobotics.h> //include library
MakeItRobotics bulldozer; //declare object
// * Power Up Init.
Serial.begin(10420); //tell the Arduino to communicate with Make: it PCB
bulldozer.remote_setup(); //remote control setup
delay(500); //delay 500ms
bulldozer.all_stop(); //stop all motors
// * Main Loop
static unsigned int valueo=0; //old remote control code
static unsigned int valuen=0; //new remote control code
valuen=bulldozer.remote_value_read(); //read code from remote control
if(valuen!=valueo) //if the remote control code is different than the previous code, then change status
valueo=valuen; //refresh the previous code
if(valueo==SW1) //SW1 action
bulldozer.bulldozer_head_up(0); //stop bulldozer blade
bulldozer.go_forward(60); //go forward
else if(valueo==SW3) //SW3 action
bulldozer.go_backward(60); //go backward
else if(valueo==SW2) //SW2 action
bulldozer.bulldozer_head_up(0); //stop bulldozer head
bulldozer.turn_front_left(60); //turn left
else if(valueo==SW4) //SW4 action
bulldozer.turn_front_right(60); //turn right
else if(valueo==SW5) //SW5 action
bulldozer.move_stop(); //stop wheels
bulldozer.bulldozer_head_up(60); //move bulldozer blade up
else if(valueo==SW6) //SW6 action
bulldozer.bulldozer_head_down(60); //move bulldozer blade down
else //if no buttons are pushed
  • Remote Scan
    ISR(PCINT0_vect) //interrupt code
    bulldozer.remote_scan(); //analyze signal from RadioShack Make: it Robotics Remote Control
Ken Shirriff’s library works with TV remotes of about any protocol.
You would need to see if it works with your receiver, though.
Hi. Thanks for answering, but I am a little new to arduino and do not no how to incorporate this into my project. I am looking for a way to find and replace the frequencies on the robot remote with the ones from my remote.
First you need to download his library and install it. In Ken's examples, there's a sketch which allows you test any remote and see what code it generates on any button. I forget what it's called, something like IRDump or similar?
Then you change your code to use his library, and change each code that your sketch expects (like say SW1) to the code of whatever button you're planning to use on your remote (say for example the "channel+" button produces a code xyz12345).
Hi, I tried that, and it gave me several error messages. I just need to know in which included part the frequencies are declared.
PATARDUINO: it gave me several error messages.
You should list them here...
I'm not sure what that means
