I am using the irremote library receive/dump sketch to capture an ir remote signal where i can copy the cmd & address code down and then use it in the send sketch to play it back, and that works fine. But i really want it to automatically resend it as soon as it gets it. Like a relayer. Is there a better sketch that will do this?
Better than what sketch?
I think @zball is talking about the ReceiveDump example sketch from the IRremote library.
* ReceiveDump.cpp
* Dumps the received signal in different flavors.
* Since the printing takes so much time (200 ms @115200 for NEC protocol, 70ms for NEC repeat),
* repeat signals may be skipped or interpreted as UNKNOWN.
* This file is part of Arduino-IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
* MIT License
* Copyright (c) 2020-2024 Armin Joachimsmeyer
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is furnished
* to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
* CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
* OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include <Arduino.h>
#include "PinDefinitionsAndMore.h" // Define macros for input and output pin etc.
#if !defined(RAW_BUFFER_LENGTH)
// For air condition remotes it requires 600 (maximum for 2k RAM) to 750. Default is 112 if DECODE_MAGIQUEST is enabled, otherwise 100.
# if (defined(RAMEND) && RAMEND <= 0x4FF) || (defined(RAMSIZE) && RAMSIZE < 0x4FF)
#define RAW_BUFFER_LENGTH 180
# elif (defined(RAMEND) && RAMEND <= 0x8FF) || (defined(RAMSIZE) && RAMSIZE < 0x8FF)
#define RAW_BUFFER_LENGTH 600
# else
#define RAW_BUFFER_LENGTH 750
# endif
#endif
* MARK_EXCESS_MICROS is subtracted from all marks and added to all spaces before decoding,
* to compensate for the signal forming of different IR receiver modules. See also IRremote.hpp line 142.
* You can change this value accordingly to the receiver module you use.
* The required value can be derived from the timings printed here.
* Keep in mind that the timings may change with the distance
* between sender and receiver as well as with the ambient light intensity.
#define MARK_EXCESS_MICROS 20 // Adapt it to your IR receiver module. 20 is recommended for the cheap VS1838 modules.
//#define RECORD_GAP_MICROS 12000 // Default is 8000. Activate it for some LG air conditioner protocols
//#define DEBUG // Activate this for lots of lovely debug output from the decoders.
#include <IRremote.hpp>
// Configure the Arduino
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin(115200); // Status message will be sent to PC at 9600 baud
#if defined(__AVR_ATmega32U4__) || defined(SERIAL_PORT_USBVIRTUAL) || defined(SERIAL_USB) /*stm32duino*/|| defined(USBCON) /*STM32_stm32*/|| defined(SERIALUSB_PID) || defined(ARDUINO_attiny3217)
delay(4000); // To be able to connect Serial monitor after reset or power up and before first print out. Do not wait for an attached Serial Monitor!
#endif
// Just to know which program is running on my Arduino
Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
// Start the receiver and if not 3. parameter specified, take LED_BUILTIN pin from the internal boards definition as default feedback LED
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
Serial.print(F("Ready to receive IR signals of protocols: "));
printActiveIRProtocols(&Serial);
Serial.println(F("at pin " STR(IR_RECEIVE_PIN)));
// infos for receive
Serial.print(RECORD_GAP_MICROS);
Serial.println(F(" us is the (minimum) gap, after which the start of a new IR packet is assumed"));
Serial.print(MARK_EXCESS_MICROS);
Serial.println(F("Because of the verbose output (>200 ms at 115200 baud), repeats are not dumped correctly!"));
Serial.println(F("If you receive protocol NEC, Samsung or LG, run also ReceiveDemo to check if your actual protocol is eventually NEC2 or SamsungLG, which is determined by the repeats"));
// The repeating section of the code
if (IrReceiver.decode()) { // Grab an IR code
// At 115200 baud, printing takes 200 ms for NEC protocol and 70 ms for NEC repeat
Serial.println(); // blank line between entries
Serial.println(); // 2 blank lines between entries
IrReceiver.printIRResultShort(&Serial);
// Check if the buffer overflowed
if (IrReceiver.decodedIRData.flags & IRDATA_FLAGS_WAS_OVERFLOW) {
Serial.println(F("Try to increase the \"RAW_BUFFER_LENGTH\" value of " STR(RAW_BUFFER_LENGTH) " in " __FILE__));
// see also https://github.com/Arduino-IRremote/Arduino-IRremote#compile-options--macros-for-this-library
if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
Serial.println(F("Received noise or an unknown (or not yet enabled) protocol"));
IrReceiver.printIRSendUsage(&Serial);
Serial.println(F("Raw result in internal ticks (50 us) - with leading gap"));
IrReceiver.printIRResultRawFormatted(&Serial, false); // Output the results in RAW format
Serial.println(F("Raw result in microseconds - with leading gap"));
IrReceiver.printIRResultRawFormatted(&Serial, true); // Output the results in RAW format
Serial.print(F("Result as internal 8bit ticks (50 us) array - compensated with MARK_EXCESS_MICROS="));
Serial.println(MARK_EXCESS_MICROS);
IrReceiver.compensateAndPrintIRResultAsCArray(&Serial, false); // Output the results as uint8_t source code array of ticks
Serial.print(F("Result as microseconds array - compensated with MARK_EXCESS_MICROS="));
IrReceiver.compensateAndPrintIRResultAsCArray(&Serial, true); // Output the results as uint16_t source code array of micros
IrReceiver.printIRResultAsCVariables(&Serial); // Output address and data as source code variables
IrReceiver.compensateAndPrintIRResultAsPronto(&Serial);
* Example for using the compensateAndStorePronto() function.
* Creating this String requires 2210 bytes program memory and 10 bytes RAM for the String class.
* The String object itself requires additional 440 bytes RAM from the heap.
* This values are for an Arduino Uno.
// Serial.println(); // blank line between entries
// String ProntoHEX = F("Pronto HEX contains: "); // Assign string to ProtoHex string object
// if (int size = IrReceiver.compensateAndStorePronto(&ProntoHEX)) { // Dump the content of the IReceiver Pronto HEX to the String object
// // Append compensateAndStorePronto() size information to the String object (requires 50 bytes heap)
// ProntoHEX += F("\r\nProntoHEX is "); // Add codes size information to the String object
// ProntoHEX += size;
// ProntoHEX += F(" characters long and contains "); // Add codes count information to the String object
// ProntoHEX += size / 5;
// ProntoHEX += F(" codes");
// Serial.println(ProntoHEX.c_str()); // Print to the serial console the whole String object
IrReceiver.resume(); // Prepare for the next IR frame
Ever seen ReceiveAndSend example???
