IR Remote codes change when changing speed using Arduino Motor Shield.
I will check that out when I get home, but it makes sense. I had the same issue with cross feed when using a ping sensor on a servo. I tried to use ribbon cable to make it all pretty like and separating the wires fixed the problem.
