Hello all,
I am currently working on a project which uses an IR remote to control an up/ down counter ic. I'm working with the following code:
#include <IRremote.h>
int IRpin = 11; // pin for the IR sensor
IRrecv irrecv(IRpin);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
pinMode(13, OUTPUT);//counter up
pinMode(12, OUTPUT);//counter down
pinMode(10, OUTPUT);//reset
digitalWrite(10, HIGH);
digitalWrite(10, LOW);//reset counters
if (irrecv.decode(&results))
irrecv.resume(); // Receive the next value
switch(results.value)
case 1168:
// left up
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(10); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
delay(500); // wait for a second
case 3216:
// left down
digitalWrite(12, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(12, LOW); // turn the LED off by making the voltage LOW
case 1808:
// left +3
case 304:
//left reset
The problem I am experiencing is that when I hit a button on the remote, the program seems to hold that remote code and continually carries out the switch case for that code. The desired effect is that the program would take the input, carry out the switch case once, and then wait for the next input. Any suggestions on what I can add to the code to get the desired effect?
Thank you
Mike
