Hi I'm Novice Urduino user looking for help to debug what is going wrong with the following code. I've searched the forums and haven't been able to find the exact solution to my isuue.
Project context: a simple scoreboard using a WS2812 Led Strip and generic IR remote to change score . I believe Remote is NEC protocol. The Example code here is a stripped down test version to display the incremental score 0 - 9 on a single 7segment - with 1 led per segment.
Issue: I have extracted the Remote Protocol and HEX value for a single button using the first code example below. The result is Protocol 8 and HEX 4B, which I have then defined as 0x4B in the main code below.
The main code does not appear to be decoding the IR signal and returns Protocol Unknown and an value of 0 when the remote button is pressed.
I appreciate any guidance or assistance
This code retrieves the Protocol and Button value:
Protocol: 8
Command: 75
CommandHEX: 4B
#include <IRremote.h>
#include <SoftwareSerial.h>
#define IR_RECEIVE_PIN 7
// #define IR_BUTT_HOMEUP 4B 75 B44BFE01 //These are the value returned - have captured here
IrReceiver.begin(IR_RECEIVE_PIN);
/* if (IrReceiver.decode()) {
IrReceiver.resume();
int command = IrReceiver.decodedIRData.command;
Serial.println(command);
if (IrReceiver.decodedIRData.protocol != UNKNOWN) {
unsigned long command = IrReceiver.decodedIRData.command;
Serial.print("Protocol: ");
Serial.println(IrReceiver.decodedIRData.protocol);
Serial.print("Command: ");
Serial.print("CommandHEX: ");
Serial.println(command, HEX);
//handleIRInput(command);
Serial.println("Unknown protocol");
IrReceiver.resume(); // Receive the next value
The following Code returns:
Unknown protocol
Command: 0
#include <FastLED.h>
#define NUM_LEDS 35 // Total number of LEDs for testing (1 LED per segment)
#define DATA_PIN 6 // Data pin for LED strip
#define IR_RECEIVE_PIN 7 // Pin for IR receiver
CRGB leds[NUM_LEDS];
IRrecv irrecv(IR_RECEIVE_PIN);
int scoreTeamA = 0;
// Segment configuration for a seven-segment display
const uint8_t segments[10][7] = {
{1, 1, 1, 1, 1, 1, 0}, // 0
{0, 1, 1, 0, 0, 0, 0}, // 1
{1, 1, 0, 1, 1, 0, 1}, // 2
{1, 1, 1, 1, 0, 0, 1}, // 3
{0, 1, 1, 0, 0, 1, 1}, // 4
{1, 0, 1, 1, 0, 1, 1}, // 5
{1, 0, 1, 1, 1, 1, 1}, // 6
{1, 1, 1, 0, 0, 0, 0}, // 7
{1, 1, 1, 1, 1, 1, 1}, // 8
{1, 1, 1, 1, 0, 1, 1} // 9
// Update this with the correct value from the IR detection sketch
#define BUTTON_A_INC 0x4B // Correct button value
Serial.begin(9600); // Start the serial communication
FastLED.addLeds<WS2812, DATA_PIN, GRB>(leds, NUM_LEDS);
irrecv.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK); // Start the receiver
FastLED.clear();
FastLED.show();
if (irrecv.decode()) {
if (irrecv.decodedIRData.protocol != UNKNOWN) {
unsigned long command = irrecv.decodedIRData.command;
Serial.println(irrecv.decodedIRData.protocol);
irrecv.resume(); // Receive the next value
displayScores();
void handleIRInput(unsigned long value) {
switch(value) {
case BUTTON_A_INC:
scoreTeamA = (scoreTeamA < 99) ? scoreTeamA + 1 : 99;
Serial.println("Incrementing Team A Score");
default:
Serial.println("Unknown command");
void displayScores() {
setDigit(0, scoreTeamA % 10, CRGB::Red); // Units digit of Team A score
void setDigit(int digitIndex, int number, CRGB color) {
int offset = digitIndex * 7; // Calculate LED offset for each digit
for (int segment = 0; segment < 7; segment++) {
leds[offset + segment] = segments[number][segment] ? color : CRGB::Black;
FastLED.show();
