IR REMOTE MOMENTARY OUT HELP
Hello Forum
As a newbie to this forum and arduino I need expert help to my IR project .
#include <IRremote.h>
int IRpin = 3;
int LED = 13;
IRrecv irrecv(IRpin);
decode_results results;
irrecv.enableIRIn();
pinMode(LED, OUTPUT);
if (irrecv.decode(&results))
irrecv.resume();
if (results.value == 0xb54a50af)
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
This code is working with my remote control but I need momentary output from pin 13.
according to this code when I press the proper remote key (0xb54a50af) the pin 13 is latching high and not going low until I press any other remote key .
All I need is until I'm pressing the proper remote key (0xb54a50af) pin 13 should go high and when I release it pin 13 should go low.
I checked the whole web but I couldn't find momentary on IR (arduino ) example code.
Please help me. :o
Kamaj
sketch_jun01a.ino (469 Bytes)
i am also a new user i have tried so many codes from web but i coudnt fine its working
results.value will remain its value of 0xb54a50af until a new value is received. To turn off the LED change its value when there is no longer anything received.
:o
Maybe this will do:
When pin 13 is set HIGH, start a timing sequence for a period you want.
When the period has been satisfied, set pin 13 LOW.
You can use the BWD (blink without delay) example in the IDE as a aid for the timing.
Edit
On second thought, you might be able to modify the library (a big job though).
As long as the repeat code comes in this signals your code to keep 13 high.
When the repeat code dissapears, you make led 13 low.
Try this - UNTESTED
    irrecv.resume();
    results.value == 0x00000000;
UKHeliBob:
Try this - UNTESTED
    irrecv.resume();
hi ukhelibob,
thank you for the code.i tried it and this works just the same as before not as momentary switch.it seems arduino is expecting an IR code valued like this ( results.value == 0x00000000;)
but i tried some AVR basic program in that your suggestion (results.value == 0x00000000;) works.but those programs don't have 32 bit NEC IR libraries.
do you have any other advice
thank you
kamaj
Bob may have ment:
results.value = 0x00000000;
LarryD:
Bob may have ment:
Indeed I did, thanks for spotting it.
The intention is to change results.value to anything but 0xb54a50af when the button is not pressed.
Dear larryD and ukhelibob,
thank you so much for helping me..!!
I tried results.value=0x00000000 then arduino totally stopped responding to IR.
Im newly building a retro type amplifier, in that there is a motor assisted volume control .my main objective is for it to operate remotely(the motor) and operate 1 relay as a power on/off switch.
so I need 1 latching output for power on/off, and 2 momentarily outputs for move volume cont motor left/right, from arduino using IR remote.I have done the latching part from copying some source codes and it is working.But I need help for momentary outputs.
LarryD as you mentioned to (edit) modify the IR library,if i do that is it going to effect my latching output? :o
You changed your code. You did not post the new code.
ALL pin state changes on the Arduino are latching.
It is up to YOU to make sure that you change the state again when appropriate.
You should NOT need to do that.
Most remotes send a different code when a switch is held down. You need to determine if yours does, and use that value to mean "repeat last action". Of course, this requires that you remember the last action.
Dear All;
Very sorry for not having the time to reach you all as i was stuck in the job..and thank you for all the replies...i have tried each and every instruction that everyone gave but as a newbie to programming and i am still stuck in the same place of the code...
Dear PaulS... i tried checking my remote controller with your last instruction and it has only one value..is there anything else i can do..i just need output momentarily on and off when i press and release the remote controller..please help..
thank you..!!
kamaj
