IR Remote Question
Hello, im a bit Stuck with a Problem.
I have a Remote:
Power ON/OFF
Mute
Buttons: 1- 6
Volume Down
Volume Up
This is my Code (i DON'T use HEX as my Remote is a NEC Type.
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
void dump(decode_results *results) {
int count = results->rawlen;
Serial.print(results->value); // prints the button code
if(results->value == 83595375){
Serial.print("Ein/Aus gedrückt");
else if (results->value == 83621895){
Serial.print("Mute Gedrückt");
else if (results->value == 83593335){
Serial.print("Button 1 gedrückt ");
else if (results->value == 83601495){
Serial.print("Button 2 Gedrückt ");
else if (results->value == 83617815){
Serial.print("Button 3 gedrückt ");
else if (results->value == 83591295){
Serial.print("Button 4 gedrückt ");
else if (results->value == 83577015){
Serial.print("Button 5 gedrückt ");
else if (results->value == 83619855){
Serial.print("Button 6 gedrückt ");
else if (results->value == 83581095){
Serial.print("Volume Leise gedrückt ");
else if (results->value == 83587215){
Serial.print("Volume Laut gedrückt ");
if (irrecv.decode(&results)) {
dump(&results);
irrecv.resume(); // Receive the next value
Works fine. Later i want to turn on/off led's (relays)
My Question is, if i press and HOLD a button it generates the Code: 4294967295 (Loop Code)
Regardless which Button i press. What i want to do is with the Volume Up/Down Buttons i want to loop the code generated by these dwo buttons when i hold the key down.
But since it does NOT generate a continuous result of 83581095 or 83587215 but it generates the loop code (4294967295 )
What i want, is this
Volume Up:
83587215
83587215
83587215
83587215
83587215
83587215
83587215
83587215
etc....
But it currently does this
Volume Up:
83587215
4294967295
4294967295
4294967295
4294967295
4294967295
4294967295
4294967295
4294967295
Is there any Chance or Trick to keep looping the correct code?
How did you guys do it? Save the first code in EPROM and then if the loop code gets activated read the last entry from the EPROM and writes it each time the loop code is supposed to be on my Serial Monitor? Thats crap....to complicated.
Thank you for the Input
Randy
Unless I'm missing something (it is late here) it seems fairly straightforward. At the top of your oddly-named dump() routine store results->value in a variable unless it's the loop code and the variable currently contains one of the codes you want to repeat. In that case just leave the variable alone.
Then your if/else string operates on the variable which contains the code just received unless that code was a "loop" after a volume up/down in which case it contains the last volume up/down code.
Steve
4294967295 being the 'repeat code'
In your sketch, when you see a 4294967295 you just repeat the last valid code that wasn’t 4294967295.
