ir remote relay control
Need help with code
I like too do this:
I press on the IR remote button (1) then :
// Reley going too turn on and off
digitalWrite(rele1, HIGH);
digitalWrite(rele2, HIGH);
delay(5000);
digitalWrite(rele2, LOW);
digitalWrite(rele1, LOW);
delay(5000);
Then Repeat from the start. Until I press the button again (IR remote) or press other button
LED blink script + IR remote too turn the script on and off
Here is code:
#include <IRremote.h>
int RECV_PIN = 11;
int relay1 = 2;
int relay2 = 3;
int relay3 = 4;
int relay4 = 5;
int on = 0;
int on1 = 0;
int on2 = 0;
int on3 = 0;
IRrecv irrecv(RECV_PIN);
decode_results results;
  pinMode(relay4, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay2, OUTPUT);
  pinMode(relay1, OUTPUT);
  pinMode(13, OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
unsigned long last = millis();
  if (irrecv.decode(&results))
    if (results.value == 0xF171)
    { // Remote Control Power Code
      // If it's been at least 1/4 second since the last
      // IR received, toggle the relay
      if (millis() - last > 250)
        on = !on;
        digitalWrite(relay1, on ? HIGH : LOW);
      last = millis();
    else if (results.value == 0xF1B1)
        on1 = !on1;
        digitalWrite(relay2, on1 ? HIGH : LOW);
      last = millis();
    else if (results.value == 0xF1A1)
        on2 = !on2;
        digitalWrite(relay3, on2 ? HIGH : LOW);
      last = millis();
    else if (results.value == 0xF121)
        on3 = !on3;
        digitalWrite(relay4, on3 ? HIGH : LOW);
      last = millis();
    irrecv.resume(); // Receive the next value
This should get you started:
int RECV_PIN = 2; //IR receive pin goes here
int relay_1 = 13; //relay driver goes here
boolean flag = false;
  pinMode(relay_1, OUTPUT);
    if (flag == false && results.value == your_HEX_code)
      digitalWrite(relay_1, HIGH);
      last = millis();
      flag = true;
  if(flag == true && millis() - last >= 5000)
    digitalWrite(relay_1, LOW);
    flag = false;
  // other non blocking code goes here
} //END of loop()
You'll need to hold the remote button for a long time.
Hi. Is not working. Is not turn relay on and of and on etc. But just turn it on.
The shuld be like a led blink script just use IR remote too turn it on or off
LarryD:
      last = millis();
      flag = true;
    flag = false;
} //END of loop()
Works fine here. - What changes have you made to the sample sketch? - How do you have things wired?
It work. But the led/reley is not turn it on and off and on and off etc. Just turn on and off.
I like too turn the on. Then the automatic turn the relay on and off and repeat that too I turn it off
There:
int RECV_PIN = 11; //IR receive pin goes here
int relay_1 = 2; //relay driver goes here
    if (flag == false && results.value == 0xFF18E7)
      last = millis();
      flag = true;
    flag = false;
} //END of loop()
Try this.
What do you see on the serial monitor?
    Serial.println(results.value,HEX);
      last = millis();
      flag = true;
    flag = false;
} //END of loop()
This if I turn it on:
FFFF18E7 FFFFFFFF
Please explain this a bit more.
Try:
    //if (flag == false && results.value == 0xFF9867)
      last = millis();
      flag = true;
  if(flag == true && millis() - last >= 1000)
    digitalWrite(relay_1, !digitalRead(relay_1));
    last =last + 1000;
    //flag = false;
} //END of loop()
My english is bad. but i try.
  1. I going too turn on a (script)
  2. Script going too turn on different relay and led, like this:
// just a example
digitalWrite(RED_PIN, LOW);
digitalWrite(GREEN_PIN, LOW);
digitalWrite(Relay HIGH);
digitalWrite(Saftpump, HIGH);
digitalWrite(Vannpump, HIGH);
delay(5000);
digitalWrite(Vannpump, LOW);
digitalWrite(Saftpump, LOW);
digitalWrite(Relay, HIGH);
digitalWrite(BLUE_PIN, LOW);
  1. Then it automatic loop this script.
  2. Then I turn it off on the same button then i turn it on
If you understanad.
And the code you send me. Is just turn the relay on (5000) and then it turn off again. I like it too loop it :slight_smile:
It work :smiley: But I can`t turn it off
Not sure what you want.
In this version the IR code starts the flashing then IR button stops the flashing.
    //if (flag == false && results.value == 0xFF18E7)
    if (results.value == 0xFF18E7)
      last = millis();
      flag = !flag;
    last =last + 1000;
} //END of loop()
Sorry if (flag == false && results.value == 0xFF18E7) This line was wrong, it should be if (results.value == 0xFF18E7)
Thx it works :D
Now the last question.
How do I add more button/script like you made? Going too have 2-3 more.
like this:
if (results.value == 0xFF18E7) { digitalWrite(relay_1, LOW); last = millis(); flag = !flag; } irrecv.resume(); // Receive the next value }
if(flag == true && millis() - last >= 1000) { digitalWrite(relay_1, !digitalRead(relay_1)); last =last + 1000;
That is for your homework ;)
Test time. What does "flag" do?
Yes :smiley:
I dont know. can you explain? :slight_smile:
This is loop the relay off
last =last + 1000;
//flag = false;
if (results.value == 0xFF18E7) { . . . flag = !flag; {
The above toggles flag when the IR button is pushed. That is: flag = !flag; If flag was true it becomes false. If flag was false it becomes true. When you press a remote key you want to start flashing (flag == true) then stop flashing on the second push (flag == false) . . .
When: - flag is true it will ENABLE timing in the next if() section - flag is false, it will DISABLE timing in the next if() section
if(flag == true && millis() - last >= 1000) //when flag == true you allow the if function to test milli() - last . . .
What does this do? digitalWrite(relay_1, !digitalRead(relay_1));
Aah:) So then it becomes difficult to make more.
hmm digitalWrite(relay_1, !digitalRead(relay_1));
Think. DigitalRead get the LOW/HIGH verdi and put it in digitalWrite
