IR REMOTE SENSING PROGRAM COMPILING ERROR
I AM GETTING BELOW ERROR
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
I AM GETTING THE BELOW ERROR
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: ‘TKD2’ was not declared in this scope
MY PROGRAM IS BELOW
#include <IRremote.h>
#include <IRremoteInt.h>
#include <IRremoteTools.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results))
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
Can you please post a copy of your sketch, using code tags?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Have you got all three libraries installed?
Tom..... :slight_smile:
RAVISHANKAR:
I am getting shouting.
I ignore shouting.
Get your caps lock key fixed, varlet.
You have to delete the RobotIRemote library from the libraries folder.
In my case, this solved the problem.
