The value that i got was like this:
Decoded RC6 10001 (20 bits)
raw code:(42){-11640,2750,900,400,900,500,400,450,400,450,900,950,350,500,400,450,450,450,400,450,450,450,450,450,400,450,450,500,400,450,400,500,400,450,450,450,400,500,400,450,400,950}
- IRremote: IRrecvDump - dump details of IR codes with IRrecv
- An IR detector/demodulator must be connected to the input RECV_PIN.
- Version 0.1 July, 2009
- Copyright 2009 Ken Shirriff
http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
// Dumps out the decode_results structure.
// Call this after IRrecv::decode()
// void * to work around compiler issue
//void dump(void *v) {
// decode_results *results = (decode_results *)v
void dump(decode_results *results) {
int count = results->rawlen;
if (results->decode_type == UNKNOWN) {
Serial.println(“Could not decode message”);
else {
if (results->decode_type == NEC) {
Serial.print("Decoded NEC: ");
else if (results->decode_type == SONY) {
Serial.print("Decoded SONY: “);
else if (results->decode_type == RC5) {
Serial.print(“Decoded RC5: “);
else if (results->decode_type == RC6) {
Serial.print(“Decoded RC6: “);
Serial.print(results->value, HEX);
Serial.print(” (”);
Serial.print(results->bits, DEC);
Serial.println(” bits)”);
Serial.print(“Raw (”);
Serial.print(count, DEC);
Serial.print(”): ");
for (int i = 0; i < count; i++) {
if ((i % 2) == 1) {
Serial.print(results->rawbuf_*USECPERTICK, DEC);_
- else {*
Serial.print(-(int)results->rawbuf_USECPERTICK, DEC);_
_ }_
_ Serial.print(" “);_
_ }_
_ Serial.println(”");_
_}_
_ if (irrecv.decode(&results)) {_
_ Serial.println(results.value, HEX);_
_ dump(&results);_
_ irrecv.resume(); // Receive the next value*_
