IR-Sender bauen
Hallo Community,
Ich bin auf der suche nach einer Schaltung für einen IR-Sender: Bei der Schaltung soll nach dem betätigen eines Schalters ein beliebiges IR Signal gesendet werden.
Kann mir von euch jemand weiter helfen?
Mfg
Dome
Eigentlich recht simpel …
 * IRrecord: record and play back IR signals as a minimal
 * An IR detector/demodulator must be connected to the input RECV_PIN.
 * An IR LED must be connected to the output PWM pin 3.
 * A button must be connected to the input BUTTON_PIN; this is the
 * send button.
 * A visible LED can be connected to STATUS_PIN to provide status.
 * The logic is:
 * If the button is pressed, send the IR code.
 * If an IR code is received, record it.
 * Version 0.11 September, 2009
 * Copyright 2009 Ken Shirriff
 * http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
int BUTTON_PIN = 12;
int STATUS_PIN = 13;
IRrecv irrecv(RECV_PIN);
IRsend irsend;
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  pinMode(BUTTON_PIN, INPUT);
  pinMode(STATUS_PIN, OUTPUT);
// Storage for the recorded code
int codeType = -1; // The type of code
unsigned long codeValue; // The code value if not raw
unsigned int rawCodes[RAWBUF]; // The durations if raw
int codeLen; // The length of the code
int toggle = 0; // The RC5/6 toggle state
// Stores the code for later playback
// Most of this code is just logging
void storeCode(decode_results *results) {
  codeType = results->decode_type;
  int count = results->rawlen;
  if (codeType == UNKNOWN) {
    Serial.println("Received unknown code, saving as raw");
    codeLen = results->rawlen - 1;
    // To store raw codes:
    // Drop first value (gap)
    // Convert from ticks to microseconds
    // Tweak marks shorter, and spaces longer to cancel out IR receiver distortion
    for (int i = 1; i <= codeLen; i++) {
      if (i % 2) {
        // Mark
        rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK - MARK_EXCESS;
        Serial.print(" m");
      else {
        // Space
        rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK + MARK_EXCESS;
        Serial.print(" s");
      Serial.print(rawCodes[i - 1], DEC);
    Serial.println("");
  else {
    if (codeType == NEC) {
      Serial.print("Received NEC: ");
      if (results->value == REPEAT) {
        // Don't record a NEC repeat value as that's useless.
        Serial.println("repeat; ignoring.");
        return;
    else if (codeType == SONY) {
      Serial.print("Received SONY: ");
    else if (codeType == RC5) {
      Serial.print("Received RC5: ");
    else if (codeType == RC6) {
      Serial.print("Received RC6: ");
    else {
      Serial.print("Unexpected codeType ");
      Serial.print(codeType, DEC);
      Serial.println("");
    Serial.println(results->value, HEX);
    codeValue = results->value;
    codeLen = results->bits;
void sendCode(int repeat) {
    if (repeat) {
      irsend.sendNEC(REPEAT, codeLen);
      Serial.println("Sent NEC repeat");
    else {
      irsend.sendNEC(codeValue, codeLen);
      Serial.print("Sent NEC ");
      Serial.println(codeValue, HEX);
    irsend.sendSony(codeValue, codeLen);
    Serial.print("Sent Sony ");
  else if (codeType == RC5 || codeType == RC6) {
    if (!repeat) {
      // Flip the toggle bit for a new button press
      toggle = 1 - toggle;
    // Put the toggle bit into the code to send
    codeValue = codeValue & ~(1 << (codeLen - 1));
    codeValue = codeValue | (toggle << (codeLen - 1));
      Serial.print("Sent RC5 ");
      irsend.sendRC5(codeValue, codeLen);
    else {
      irsend.sendRC6(codeValue, codeLen);
      Serial.print("Sent RC6 ");
  else if (codeType == UNKNOWN /* i.e. raw */) {
    // Assume 38 KHz
    irsend.sendRaw(rawCodes, codeLen, 38);
    Serial.println("Sent raw");
int lastButtonState;
  // If button pressed, send the code.
  int buttonState = digitalRead(BUTTON_PIN);
  if (lastButtonState == HIGH && buttonState == LOW) {
    Serial.println("Released");
    irrecv.enableIRIn(); // Re-enable receiver
  if (buttonState) {
    Serial.println("Pressed, sending");
    digitalWrite(STATUS_PIN, HIGH);
    sendCode(lastButtonState == buttonState);
    digitalWrite(STATUS_PIN, LOW);
    delay(50); // Wait a bit between retransmissions
  else if (irrecv.decode(&results)) {
    storeCode(&results);
    irrecv.resume(); // resume receiver
  lastButtonState = buttonState;
Hier gefunden !
Danke für deine schnelle Antwort!
Aber ich sich eher nach einer Schaltung, die ohne Arduino funktioniert(Arduino sparen :wink: ). Ich möchte das Signal an der einen Stelle Senden und an einer anderen Stelle mit einem Arduino umsetzen.
Dome2075: Danke für deine schnelle Antwort!
Da kannst Du doch als Sender irgendeine Fernbedienung nehmen. Mit dem Arduino kannst Du doch jedes IR signal interpretieren !
leider ist der (Schalter) ein Relaiskontakt eines Gerätes....
Beschreibe doch mal genau, was du machen willst. Das wird aus deinen Post überhaupt nicht klar. Mal soll der Arduino, was senden, dann schreibst du so als ob er empfangen soll. Dann kommt ein zweiter ins Spiel oder auch nicht.
Also: Ich habe ein Gerät, dass beim einschalten einen Relaiskontakt schlisst. Dort möchte ich eine Schaltung anbringen, die beim schlissen des Kontaktes ein IR-Befehl sendet (IR-Sender). An einer Anderen Stelle Soll der IR-Befehl mittels eines Arduino umgesetzt werden.
Die Empfängerseite ist bereits von einem anderen Projekt vorhanden.
Hoffe jetzt ist alles verständlich...
Dome2075: Also: Ich habe ein Gerät, dass beim einschalten einen Relaiskontakt schlisst. Dort möchte ich eine Schaltung anbringen, die beim schlissen des Kontaktes ein IR-Befehl sendet (IR-Sender).
Wie bereits geschrieben. Nimm irgendeine Fernbedienung, zerlege sie und dann das ding an deinen Relaiskontakt mit ran. Wenn du kein freien schaltkontakt hast setz noch ein kleines Relais mit ran... Fertig :-)
AndreasVan:
Wie bereits geschrieben. Nimm irgendeine Fernbedienung, zerlege sie und dann das ding an deinen Relaiskontakt mit ran. Wenn du kein freien schaltkontakt hast setz noch ein kleines Relais mit ran… Fertig :slight_smile:
Das sehe ich nicht zielführend da ich annehme, daß der Relaiskontakt für die Dauer des Eingeschalten-seins des Gerätes zu ist.
Grüße Uwe
