R1 limits the Arduino pin 3 output current to a safe level.
5V out —— 470R—— base—>|—emitter —— GND
5v - .7Vbe = Vrb = 4.3V
Ib(rb)= 4.3Vrb / 470R ≈ 9mA
If you reduce Rb to 220R then 4.3Vrb / 220R ≈ 19mA
A 5v UNO can safely supply 20mA so a 220R would work.
If the IR LED can have 100mA maximum, a series resistor will be needed to limit the transistor collector current to 100mA.
You can use a different NPN BJT or N channel MOSFET transistor. At these low levels of current most BJTs and Logic level N channel MOSFETs should work.
The Base-Emitter junction acts like a diode. The junction will draw enough current to bring the Base voltage down to the forward voltage drop of the diode, about 0.6V. That will draw too much current from the Arduino pin so a current limiting resistor is used to protect the Arduino pin. It's like driving an LED where the resistor protects the Arduino and the LED from excessive current.
Yes, as long as you don't try to pull more than 40 mA (better: 20 mA) from the Arduino pin. Basically the same calculation as for an LED. Divide the voltage by the current. For a 3.3V Arduino the voltage across the resistor is about 2.7 (3.3-0.6). Divide by 0.020A to get 135 Ohms. Pick the next higher resistor you have handy.
The 'Beta' or "current gain" is the multiplier from Base current (about 20 mA) to Collector current. For example, if your load draws 2A you need a Beta of 100 or more.
So you need a transistor with a Beta over 5 (100mA/20mA). Are you using 5V or 3.3V for Vcc? Take that voltage, subtract the 1.4V forward voltage drop, and divide by 0.1A (100 mA) to calculate the series resistor that will get you 100 mA through the LED. Use the next higher resistor.
Note: If you run the ATmega328P on less than 3.78V you shouldn't be running it at 16 MHz. See the "Safe Operating Area" in the datasheet. 2.7V will get you 10 MHz, 4.5V will get you 20 MHz so 3V will max out at 11.33 MHz.
Are your LEDs designed for 20 mA? Many are 10 mA and are plenty bright at 5 mA. You should probably try an assortment of values until the LED is bright enough.
I don't know what to do about the 3V Green LED running on a 3V supply.
