Ir Sensor Activated Servo With Millis
Hey all! I'm currently using arduino to create an animatronic, and am having an issue. It's supposed to be when the ir sensor is triggered, the servo goes to 160 degrees, than 60, and continues doing that for about 20 seconds. I also have 2 other things that will be on for a couple seconds when the sensor is activated, but that part of the code works great. My current issue is that the servo only moves if the ir sensor is currently triggered, but as mentioned I want it to move for 20 without needing to hold my hand over it. I have tried using the method that uses elapsedmillis to make the servo go for a certain amount of time, but with that method, the servo moves for 21 seconds, stops, and never moves again even if the sensor is triggered. That method also messed up the timing of the 2 other things. Essentially i want the servo to go for 21 seconds when the sensor is triggered using millis. Whatever works works, so if i have to make the servo loop go a million times that's totally fine.
Code:
#include <Servo.h>
int position = 90 ;
boolean forward = false ;
unsigned long ts = millis () ;
#define DELAY 40
int servoPin = 8;
Servo servo;
# define PinSensor   9
# define PinThing1   12
# define PinThing2   13
enum { Off = LOW, On = HIGH};
void setup ()
  pinMode (PinSensor, INPUT_PULLUP);
  pinMode (PinThing1, OUTPUT);
  pinMode (PinThing2,    OUTPUT);
  digitalWrite (PinThing1, Off);
  digitalWrite (PinThing2,    Off);
  servo.attach(8);
struct Timer {
  byte           pin;
  unsigned long  duration;
  bool           on;
Timer timers [] = {
  { PinThing1, 5000 },
  { PinThing2,    2000 }
#define N_TIMERS    (sizeof(timers)/sizeof(Timer))
void loop ()
  static unsigned long msecLst;
  unsigned long msec = millis ();
  // enable timed outputs
  if (digitalRead (PinSensor) == LOW)  {
    if (millis () - ts >= DELAY)
      ts += DELAY ;   // setup timestamp for next time.
      if (forward)
        servo.write (-- position) ;  // progress the servo
        if (position == 60)  // test for reverse
          forward = false ;
        servo.write (++ position) ;  // progress the servo
        if (position == 160)  // test for reverse
          forward = true ;
    msecLst = msec;
    for (unsigned n = 0; n < N_TIMERS; n++)  {
      timers [n].on = true;
      digitalWrite (timers [n].pin, On);
  Timer *t = timers;
  for (unsigned n = 0; n < N_TIMERS; n++, t++)  {
    if (t->on && (msec - msecLst) > t->duration)  {
      digitalWrite (t->pin, Off);
      t->on = false;
Thank you all so much for your help! I've only been doing this for a couple of months so don't be suprised if it's an obvious error lol
You need to detect when the button becomes pressed rather than when it is pressed
See the StateChangeDetection example in the IDE
Hey! tried this and now not only does the servo not work, but the led only stays on if my hand is in front of the sensor. If i use it with elapsed millis the servo works, but again only once, and the led does not work at all. Code:
#include <Servo.h>
int position = 90 ;    // state variable
boolean forward = false ;   // state variable
unsigned long ts = millis () ;   // time accounting.
#define DELAY 40
int servoPin = 8;
Servo servo;
int SensorCounter = 0;   // counter for the number of button presses
int SensorState = 0;         // current state of the button
int lastSensorState = 0;     // previous state of the button
void setup ()
  servo.attach(8);
struct Timer {
  byte           pin;
  bool           on;
Timer timers [] = {
  { PinThing2,    2000 }
void loop ()
{ SensorState = digitalRead(PinSensor);
  Timer *t = timers;
      t->on = false;
      // compare the buttonState to its previous state
      if (SensorState != lastSensorState) {
        // if the state has changed, increment the counter
        if (SensorState == HIGH) {
          // if the current state is HIGH then the button went from off to on:
          SensorCounter++;
          Serial.println("on");
          Serial.print("number of button pushes: ");
          Serial.println(SensorCounter);
          // if the current state is LOW then the button went from on to off:
          Serial.println("off");
        // save the current state as the last state, for next time through the loop
        lastSensorState = SensorState;
        if (SensorCounter % 1 == 0) {
              if (forward)
                  forward = false ;
                  forward = true ;
You are saving the current sensor state as the previous sensor state only when the sensor state has changed. That is not what the StateChangeDetection example does.
You need to do it before every read of the sensor
How would i do that? Sorry I'm dumb lmao. Also would you know why the led isn't working?
Look at where it is done in the example
I'm not entirely sure what you mean by this, Where in the program is this? I want the program to run every time the ir sensor is activated, not just the first time, and from my understanding of it statechangedetection only detects if it changes once, not every time. The servo moves a tiny bit with this program, but barely at all.
Here is the StateChangeDetection example stripped to the bare bones with added comments
const int  buttonPin = A3;    // the pin that the pushbutton is attached to
int buttonState = HIGH;         // current state of the button
int lastButtonState = HIGH;     // previous state of the button
  pinMode(buttonPin, INPUT_PULLUP);
  buttonState = digitalRead(buttonPin);   //read the current button state
  if (buttonState != lastButtonState)     //if it has changed since the last time it was read
    if (buttonState == LOW)               //and is now LOW
      Serial.println("input became LOW");
    delay(50);                            //quick and dirty way to debounce
  lastButtonState = buttonState;   //save the current button state ready for the next check for a change
So from my understanding, i need to change this? right now with this code the elapsedmillis timer is not working
Frankly I suggest that you restructure your sketch into a state machine so that the code for each state can be isolated to make it easier to see what is going on
As I understand it the states would be
WAIT_FOR_TRIGGER
MOVE_TO_160_DEGREES //repeat moves and waits for 20 seconds or a fixed count
WAIT_A_BIT //using millis() for non blocking timing
MOVE_TO_60_DEGREES
Meanwhile the code can do whatever it likes in loop() as long as it does not block execution of the code. Does that sound right ?
Yep, that's essentially what I'm trying to do
This is the sort of program structure that I had in mind
//https://forum.arduino.cc/t/ir-sensor-activated-servo-with-millis/947216
enum states
  WAIT_FOR_TRIGGER,
  MOVE_TO_160_DEGREES,
  WAIT1,
  MOVE_TO_60_DEGREES,
  WAIT2
const unsigned long wait1Period = 5000;
const unsigned long wait2Period = 5000;
const unsigned long movementPeriod = 20000;
unsigned long currentTime;
unsigned long shortPeriodStartTime;
unsigned long movementPeriodStartTime;
byte currentState = WAIT_FOR_TRIGGER;
const byte triggerPin = A3;
  pinMode(triggerPin, INPUT_PULLUP);
  Serial.println("waiting for trigger");
  currentTime = millis();
  switch (currentState)
    case WAIT_FOR_TRIGGER:
      if (digitalRead(triggerPin) == LOW)
        currentState = MOVE_TO_160_DEGREES;
        movementPeriodStartTime = currentTime;
    case MOVE_TO_160_DEGREES:
      Serial.println("move to 160 degrees");  //<<<<<servo code goes here
      shortPeriodStartTime = currentTime;
      currentState = WAIT1;
    case WAIT1:
      if (currentTime - shortPeriodStartTime >= wait1Period)
        currentState = MOVE_TO_60_DEGREES;
      checkMovementPeriod();
    case MOVE_TO_60_DEGREES:
      Serial.println("move to 60 degrees");  //<<<<<servo code goes here
      currentState = WAIT2;
    case WAIT2:
  //any other non blocking code required goes here
void checkMovementPeriod()
  if (currentTime - movementPeriodStartTime >= movementPeriod)
    Serial.println("movement  period ended");
Thanks so much! it works almost perfectly, but i have one question. How would i make the servo go slower? I know with delay you can just increase delay time.
What code are you using to move the servo ?
servo.write(160);
No wonder it moves fast
For a quick and dirty way to slow down the servo movement take a look at the Servo Sweep example in the IDE, but there are better, if more complicated, ways to do it
Try using VarSpeedServo.h instead of Servo.h. That has a speed parameter to the write() command.
Steve
ayyy thanks so much, exactly what I needed!
