IR sensor and HID keyboard Arduino Uno R2
Hello,
I have been trying to build a media center remote using Arduino Uno.
  1. IR sensor with Arduino is explained here, Overview | IR Sensor | Adafruit Learning System, very through tutorial and works perfectly.
  2. HID keyboard implementation explained here, Arduino Forum and http://mitchtech.net/arduino-usb-hid-keyboard/, the two tutorials complete each other.
The problem is the combination of those two. See example code below.
After flashing “Arduino-keyboard-0.3.hex” bootloader, restarting Arduino, I press the remote button and the code runs only once, I see my led indicator on pin 13 .
What could be the problem?
#define IRpin_PIN      PIND
#define IRpin    2
// the maximum pulse we'll listen for - 65 milliseconds is a long time
#define MAXPULSE 1500
// what our timing resolution should be, larger is better
// as its more 'precise' - but too large and you wont get
// accurate timing
#define RESOLUTION 10
// What percent we will allow in variation to match the same code
#define FUZZINESS 30
// we will store up to 100 pulse pairs (this is -a lot-)
uint16_t pulses[100][2] ={0};  // pair is high and low pulse
uint8_t currentpulse = 0; // index for pulses we're storing
uint8_t buf[8] = {0}; 	/* Keyboard report buffer */
int Rarrow[] = {715, 354,46, 43,44, 45,44, 44,46, 43,44, 46,43, 44,46, 43,44, 46,43, 134,43, 133,46, 133,44, 133,44, 133,46, 133,44, 43,46, 133,44, 133,43, 134,45, 44,44, 133,46, 133,44, 43,46, 43,44, 46,43, 44,46, 43,44, 133,46, 44,43, 46,44, 133,44, 133,45, 134,43, 0};
void setup(void)
  delay(3000);
  pinMode(13, OUTPUT);
void loop(void) {
int numberpulses = 0;
numberpulses = listenForIR();
/*buf[2] =17;
Serial.write(buf, 8);	// Send keypress
releaseKey();*/
  if (IRcompare(numberpulses, Rarrow))
    digitalWrite(13, HIGH);   // set the LED on
    //Serial.print("------>");
	buf[2] = 79;
    releaseKey();
if (IRcompare(numberpulses, Larrow))
    //Serial.print("<------");
     buf[2] = 80;
    releaseKey();
     if (IRcompare(numberpulses, Uparrow))
   // Serial.print("UParrow");
	buf[2] = 82;
    releaseKey();
   if (IRcompare(numberpulses, Downarrow))
    //Serial.print("Down arrow");
	buf[2] = 81;
    releaseKey();
     if (IRcompare(numberpulses,Ok))
    //Serial.print("OKKK");
	buf[2] = 88;
    releaseKey();
 // digitalWrite(13, HIGH);   // set the LED on
   delay(100);
   digitalWrite(13, LOW);   // set the LED on
}//void
void releaseKey()
  buf[0] = 0;
  buf[2] = 0;
  Serial.write(buf, 8);	// Release key
  delay(100);
int listenForIR()
  currentpulse = 0;
  while (1) {
    if(Serial.available() >0 ){return 0;}
    uint16_t highpulse, lowpulse;  // temporary storage timing
    highpulse = lowpulse = 0; // start out with no pulse length
//  while (digitalRead(IRpin)) { // this is too slow!
    while (IRpin_PIN & _BV(IRpin)) {
       // pin is still HIGH
       // count off another few microseconds
       highpulse++;
       delayMicroseconds(RESOLUTION);
       // If the pulse is too long, we 'timed out' - either nothing
       // was received or the code is finished, so print what
       // we've grabbed so far, and then reset
       if ((highpulse >= MAXPULSE) && (currentpulse != 0)) {
        return currentpulse;
    // we didn't time out so lets stash the reading
    pulses[currentpulse][0] = highpulse;
    // same as above
    while (! (IRpin_PIN & _BV(IRpin))          ) {//_BV(IRpin) same as (1 << IRpin)
       // pin is still LOW
       lowpulse++;
       if ((lowpulse >= MAXPULSE)  && (currentpulse != 0)) {
    pulses[currentpulse][1] = lowpulse;
    // we read one high-low pulse successfully, continue!
    currentpulse++;
boolean IRcompare(int numpulses, int Signal[])
  if (numpulses > 3) {
  for (int i=0; i< numpulses-1; i++) {
    int oncode = pulses[i][1] * RESOLUTION / 10;
    int offcode = pulses[i+1][0] * RESOLUTION / 10;
    // check to make sure the error is less than FUZZINESS percent
    if ( abs(oncode - Signal[i*2 + 0]) <= (Signal[i*2 + 0] * FUZZINESS / 100)) {
   //  Serial.print(" (ok)");
    else {
   //  Serial.print(" (x)");
     return false;
    if ( abs(offcode - Signal[i*2 + 1]) <= (Signal[i*2 + 1] * FUZZINESS / 100)) {
      // we didn't match perfectly, return a false match
      return false;
  // Serial.println();
  // Everything matched!
  return true;
  return false;
