ir sensor as a detector alarm
Just purchased a 2PCS Digital 38KHz Infrared IR Sensor Transmitter Kit for Arduino and would like some help on how I am going to interface it with the arduino and the code . I was able to send a signal but the buzzer would not come on.
Thank :slight_smile:
First rule is provide enough information to enable us to know what you have done.
A program and wiring diagram would help.
Weedpharma
Transmitter? Presumably there's a receiver too?
This is the sensor http://www.ebay.com/itm/2PCS-Digital-38KHz-Infrared-IR-Sensor-Transmitter-Kit-for-Arduino-JT1-/400540617003 I connected the data pins and gave it supply and a signal is send from the photo diode when passing the receiver an led on the receiver go high to tell you it revieved a signal (it is build in)
Now I need some help to with the coding to make a buzzer go high when the receiver receives a signal from the photo diode
Well the receiver has a data pin: presumably that goes high when it receives a signal?
So just connect that to an Arduino i/o pin and read it with digitalRead. If it's high, make another pin go high for your buzzer.
(Or if the receiver's logic is inverted, look for a low on its data pin and turn your buzzer on then)
I am making this code but still is not working
int LED = 47; // IR Led on this pin
int dtect = 49 ;
void setup(){
pinMode(LED, OUTPUT);
pinMode(dtect, INPUT);
digitalWrite(LED, HIGH);
void loop(){
irsensor();
void irsensor()
if (digitalRead(dtect) == HIGH)
digitalWrite(Buzzer,HIGH);
Well no, it won't compile will it? You have a pin named Buzzer here...
... but you didn't declare a variable called Buzzer and assign it a pin number..
