I have made a LINE Follower bot but I think the coding is wrong. I have used pin 4,5,6,7 for motors and 0,1 pins for sensor
Int x;
Int y;
Void setup(){
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT):
Void loop(){
x=analogRead(0);
y=analogRead(1);
If (x>300 &&y>>300){
Digitalwrite(4,HIGH);
Digitalwrite(5,LOW);
Digitalwrite(6,HIGH);
Digitalwrite(7,LOW);
else if (x<300 && y>300){
//Turn RIGHT}
else if (x>300 && y<300){
//Turn LEFT}
else (x<300 && y<300){
//MOVE FORWARD}
Welcome to the forum AgarwalSukant (glad I don't have to pronounce that )
Its traditional here to give you a hard time for not using code tags.
See this post to save yourself some hassle. How to use this forum
This is how it should look when you do use them
You may also notice where you went wrong in this line.
Yawn
Always post code in code tags
Always use the auto format tool before posting
At least try and compile the code before posting
THE FORUM POSTING RULES ARE AT THE TOP OF THE FORUM - THEY APPLY TO YOU AND TO EVERY ONE ELSE.
Mark
What they said ^.
Also, "void" is always typed in lower-case, not with an upper-case 'V'.:-
Void setup()
Void loop()
should be:-
Same goes for "int":-
Int x;
Int y;
should be:-
int x;
int y;
And this should end in a semi-colon, not a colon:-
pinMode(7, OUTPUT):
And these:-
Digitalwrite(4, HIGH);
should look like this:-
digitalWrite(4, HIGH);
You're missing an 'if' and some closing brackets, too, as well as starting one 'if' with an upper-case 'I'.
I'd suggest that you have a closer look at the examples supplied with the IDE, then take much more care when writing your code.
I haven't checked the logic of your code, so have no idea if it will work when you finish writing it, but here's the repaired version, that actually compiles:-
int x;
int y;
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
x = analogRead(0);
y = analogRead(1);
if (x > 300 && y > 300)
digitalWrite(5, LOW);
digitalWrite(6, HIGH);
digitalWrite(7, LOW);
else if (x < 300 && y > 300)
//Turn RIGHT
else if (x > 300 && y < 300)
//Turn LEFT
else if (x < 300 && y < 300)
//MOVE FORWARD
