Ir sensor getting always blocked when senstivity get increasedi
I recently bought a IR sensor. I used a a usb cable wity negative and positive terminal ends to power it. I tried to increase its sensitivity but then it would always show that there is a obstacle. I tried to point it to the sky and it still shows the error. When i lowered the senstivity it works fine but i really want higher senstivity. What should i do? Help me
Turn the blue knob clockwise and the red knob down. That is about the best I can answer as I am not clairvoyant. You need to let us know what you have and how you connected it, a schematic is a great way of showing that. I have about 9 different IR sensors here and I do not think any of them are the same as yours. Also show the source of IR light.
Hi, @mr_minecraft
Can you please post a link to specs/data of the sensor?
Thanks.. Tom.. :grinning: :+1: :coffee: :coffee: :australia:
unfortunately, i brought it from a local store and i really don't have any specs about it. but i can send you its picture.
Yes please.
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
here:
![17101616076754058093249672379949|666x500](upload://5jhFZotl7jvLejdmhpmbSZ7f9sP.jpeg
pic:
I don't have a red knob
And we do not have the information needed to properly answer your question.
what information do you need? i would like to provide it !
Hi, @mr_minecraft
You have one of these.
And the link may help you program it.
The actual problem is that the signal led of the sensor (The bright red led at the left of the sensor)
keeps on when i increase the senstivity of the sensor. Thank you for the link BTW but my problem is not resolved compltely
From what I can see in your dim picture that is what I would expect. That sensor like several others has a digital output. The sensor has a comparator IC that takes the value of the pot and sets the signal On if light is brighter then the setpoint and off if it is below. You cannot get a level of light from this sensor. Your linked data sheet shows this: OUT pin is a 5V TTL logic output. LOW indicates no motion is detected; HIGH means motion is detected.
I wonder how many sensors you could buy for the price of a module?
Last time I bought a bag (the only bag I've needed) they were 5 cents each.
Thank you very much. But can you tell me how to properly increase the range of the sensor
