Ok, I want to set up an IR receiver that will calibrate to the environment... ( check to see how much ir light is in the environment) and then set that as the new zero level, so if the other IR receiver receives a little more ir light than that new zero ( threshold), then an led will turn on. To test this, I simply have 2 of the exact same infrared receivers hooked up the exact same way with the exact same resistors to analog 0 and 5 on the arduino. The 2 receivers are not more than 1 inch apart and are at the same level vertically. The problem is they are receiving vastly different ir values?? why?
Calibration Input =
35
Receiver Input =
140
Calibration Input =
29
Receiver Input =
142
Calibration Input =
24
Receiver Input =
136
Calibration Input =
28
Receiver Input =
134
Calibration Input =
31
Receiver Input =
141
Calibration Input =
22
Receiver Input =
138
.. They change which is obviously good because they respond to slight changes in ir light in the environment, but the values are too much unlike each other. Makes no sense. I tried switching the receivers, but get the exact same results, also tried switching the inputs to different places with the same results... :(
Also, Id like to take either 10 or 100 samples within about a second with one sensor in the setup() part and take the average reading as a threshold.. then in the loop take a constant reading to compare to the threshold.
Should I use a for loop for that?
What is it you are trying to achieve?
Because if you sample during the setup you will not need 2 different sensors and you will not be able to adjust to ambient light changes.
Where does the light you do want to detect come from?
For getting a threshold during the setup you can simply do something like:
int threshold = 0;
for(int i = 0; i < 100; i++)
threshold += analogRead(A0);
threshold = threshold / 100;
You might want to add a small delay in the loop to sample over a longer period of time to get a more average reading if necessary.
Thanks Tom, I am trying to make an IR Receiver (photodiode )light up an LED when it senses IR light that reflects off of something from the IR emitter close by. All leds will be facing vertically, and eventually they will all be covered so not affected by each other. I want the IR receiver to take in a bunch of readings when the program starts up to set the ambient light as a new zero.. (threshold maybe?) and then when the IR receiver detects a certain amount of light above that the LED will turn on. I know this uses a lot more than I do right now, but I want to start with the basics in order to get here.....
By that do you mean that the same channel shows up high or the same sensor is high.
If you swap the sensors do the readings swap?
You also need to be a bit more descriptive about the sensors (type and link to data sheet) and how they are wired up (schematic). It could be you have an error or it could be that the two sensors are just that different in sensitivity. What does the data sheet say about the sensitivity?
Ive tried different values of resistors. But equal for each sensor. So...
I have a wire from A0 on the arduino to a 1k resistor (ive also tried 500 ohm and 10k ohm), the resistor to the positive of the ir photodiode, from the negative of the diode it goes to arduino ground. I have the exact same setup for the other sensor to A5.
If I understand what you have done correctly that is wrong.
A0 should go to a resistor and the cathode of the photo sensor. Then the anode should go to ground and the other end of the resistor to +5V. Use a 10K resistor to start and if you want to improve the sensitivity (but also increase the noise) make the resistor a larger value, say 100K.
You won't even have to apply a reverse voltage to the photodiode unless you want/need it to react faster to light changes. But since in your case the limiting factor will probably be the analogRead or the upcoming multiplexing you should be fine without it.
If that doesn't help then show us a complete diagram on what and how you wired things up.
I used a 10k ohm resistor to start, then switched to two 47k ohm resistors in series for 94 k ohms, and always was 1023 reading with slight variations to 1022 and 1021 randomly. I pressed my tv remote and got no reaction. Here is how I have it set up...
5v _____ 94 ohm ______ cathode ________ A5
anode_______ground I believe this is exactly what you mean.
You have to measure between the photodiode and the resistor (identified by "Vout" in the paper I linked).
And why don't you try the simplest possible setup (i.e. no reverse voltage) if you are having troubles?
You can always change it later if you do need the reverse voltage.
5v _____ 94 ohm ______ cathode ________ A5 is separate
This is everything attached to the cathode
only thing attached to the anode of the photodiode is ground. I tried reverse and it seems to be working better though. I am also getting other photodiodes ( daylight filtering ) from mouser today.
No that is not what I said please re read what I put.
No if there is only a reverse diode across the analogue input then the input impedance is too high for the sample and hold on the input. You need an impedance of about 10k to prevent any apparent cross coupling in the multiplexer
I think you misunderstood me Mike, by simplest possible setup I was referring again to driving the photodiode in short circuit mode (i.e. cathode - resistor - anode) and reading the voltage across the resistor.
