hey guys,
using a IR SHARP Sensor P2Y0A21YK0F (0-80cm). two part question.
i need to make the serialprint give me back a distance reading in inches. the code below is for centimeters. the sensors data sheet tells me the distance 65 should be changed to about 27. i believe the voltage stays the same. And second part is to work in some smoothing. i’m pasting the code for that below after the first code set.
appreciate any advice you guys can run by me.
thanks,
Cryper
credit: this code belongs to the owner of this webpage
http://luckylarry.co.uk/arduino-projects/arduino-using-a-sharp-ir-sensor-for-distance-calculation/comment-page-1/#comment-4824
int IRpin = 1; // analog pin for reading the IR sensor
Serial.begin(9600); // start the serial port
float volts = analogRead(IRpin)0.0048828125;
// value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
float distance = 65pow(volts, -1.10);
// worked out from graph 65 = theretical distance / (1/Volts)S - luckylarry.co.uk
Serial.println(distance); // print the distance
delay(100); // arbitary wait time.
and my smoothing code
int sensor = 0;
int distRead = 0;
int distAvg = 0;
int runningtotal = 0;
int i = 0;
// initialize serial communication with computer:
// initialize all the readings to 0:
for (i=0; i < 10; i++)
distRead = analogRead(sensor);
runningtotal += distRead;
distAvg = (runningtotal / 10);
Serial.println(distAvg, DEC);
delay(4000);
