IR sensor, interrupts and arduinos
I'm trying to make my arduino sleep till I receive an IR input. I followed this great post:
It works perfectly on my arduino uno.
The arduino sleeps and wakes up only when I hit the remote.
I used pin 12 in the UNO for the IR sensor.
On my arduino pro mini it wakes up every second (the same sensor ! not just the same sensor model, but the sensor itself is the same.)
If I block the ambient light from the sensor it stops waking up. so it is not some wiring bug.
I used pin 2 on the pro mini.
Is it possible that the pro mini is more sensitive ?
Or maybe pin 2 is more sensitive ?
Any ideas ?
I use the vs1838b sensor
As you didn't specify which pro mini you have (there are 5V and 3V3 versions of it, clocked differently) I guess you have the 3V3 version.
This sensor has a built-in 38kHz filter so ambient light shouldn't affect the sensor's output.
Do you have the possibility to attach a scope to the sensor's output?
Please post the code you used for the two Arduinos (it cannot be the same).
Unfortunately I do not have a scope.
Maybe because pin 2 is close to the tx-tr pins from some strange reason the communication with the computer makes him wake up ?
The code :
#include <IRremote.h>
#include <IRremoteInt.h>
#include <avr/sleep.h>
#include <avr/power.h>
#if defined(ARDUINO_AVR_UNO)
  int RECV_PIN = 12;
  const int motor_1_control_1 = 2;
  const int motor_1_control_2 = 3;
  const int motor_1_enabled = 4;
  const int motor_2_control_1 = 5;
  const int motor_2_control_2 = 6;
  const int motor_2_enabled = 7;
  #define INTERUPT_PIN PCINT4
  #define INTERUPT_PIN_RANGE_F PCIF0
  #define INTERUPT_PIN_RANGE_C PCIE0
  #define INTERUPT_MASK PCMSK0
  EMPTY_INTERRUPT (PCINT0_vect);
#endif
#if defined(ARDUINO_AVR_PRO)
  int RECV_PIN = 2;
  const int motor_1_control_1 = 10;
  const int motor_1_control_2 = 11;
  const int motor_1_enabled = 12;
  const int motor_2_control_1 = 9;
  const int motor_2_control_2 = 8;
  #define INTERUPT_PIN PCINT19
  #define INTERUPT_PIN_RANGE_F PCIF2
  #define INTERUPT_PIN_RANGE_C PCIE2
  #define INTERUPT_MASK PCMSK2
  EMPTY_INTERRUPT (PCINT2_vect);
#endif
const unsigned long NO_ACTIVITY_TIMEOUT = 1000;  // milliseconds
unsigned long lastActivity = 0;  // when we last woke
IRrecv irrecv(RECV_PIN);
decode_results results;
  pinMode(motor_1_control_1, OUTPUT);
  pinMode(motor_1_control_2, OUTPUT);
  pinMode(motor_1_enabled, OUTPUT);
  pinMode(motor_2_control_1, OUTPUT);
  pinMode(motor_2_control_2, OUTPUT);
  pinMode(motor_2_enabled, OUTPUT);
  Serial.println("Starting");
  Serial.println(RECV_PIN);
  irrecv.enableIRIn(); // Start the receiver
unsigned long totalWakeTime = 0;
unsigned long totalSleepTime = 0;
unsigned long lastTime = 0;
void sleepFunc()
  // sleep if no activity for a while
  if (millis () - lastActivity >= NO_ACTIVITY_TIMEOUT)
    Serial.print("Going to sleep, slept ");
    Serial.print(totalSleepTime);
    Serial.print(" Been awake ");
    Serial.println(totalWakeTime);
    Serial.flush ();  // wait for Serial to finish outputting
    Serial.end ();    // shut down Serial
    noInterrupts ();  // timed sequence coming up
    INTERUPT_MASK |= bit (INTERUPT_PIN);
    PCIFR  |= bit (INTERUPT_PIN_RANGE_F);   // clear any outstanding interrupts
    PCICR  |= bit (INTERUPT_PIN_RANGE_C);   // enable pin change interrupts
    totalWakeTime += millis() - lastTime;
    lastTime = millis();
    set_sleep_mode (SLEEP_MODE_STANDBY);
    sleep_enable();
    byte old_ADCSRA = ADCSRA;
    // disable ADC to save power
    ADCSRA = 0;
    power_all_disable ();  // turn off various modules
    interrupts ();
    sleep_cpu ();
    totalSleepTime += millis() - lastTime;
    sleep_disable();
    power_all_enable ();   // enable modules again
    ADCSRA = old_ADCSRA;   // re-enable ADC conversion
    Serial.println("Waking up");
    lastActivity = millis ();
  }  // end of no activity for a couple of seconds
  if (irrecv.decode(&results))
    Serial.println(results.value, HEX);
    delay(50);
    irrecv.resume(); // Receive the next value
  sleepFunc();
Any interrupt, including communication from the computer, will wake the Arduino.
jremington:
As you can see above, the same code runs on the arduino uno and pro mini.
The arduino uno sleeps till I press a button on the remote.
The pro mini always wakes up.
I've tested them both while they are connected to the computer.
It took me several hours, but I found the problem.
Pin 2 is not PCINT19, It is PCINT18
Is there a good way to convert between pin number and the PCINT** thing ?
tautau123:
There is a beautiful pinout diagram of the Atmega328 with signed Arduino pins.
