IR sensor only read once
New Bee Profile please bare me :confused:
Working on a project
Where all working fine but issue is want to run the if only once.
Till next detect happens
here’s flow
ir sensor detect >> relay > ON & OFF>> motor rotates ( works fine)
want to stop till next ir detects.
Using L298N , IR sensor & relay
Expert guide pls
//sketch created by chetuk
int motor1pin1 = 2;
int motor1pin2 = 3;
int IRSensor = 4;
int Relay = 13;
void setup(){
pinMode(IRSensor, INPUT); // sensor pin INPUT
pinMode(Relay, OUTPUT); // Relay IN
pinMode(motor1pin1, OUTPUT);
pinMode(motor1pin2, OUTPUT);
  int statusSensor = digitalRead (IRSensor);
  if (statusSensor == 0){
    digitalWrite(Relay, HIGH);
    digitalWrite(Relay, LOW);
    digitalWrite(motor1pin1, HIGH);
    digitalWrite(motor1pin2, LOW);
    delay(2000);
    digitalWrite(motor1pin1, LOW);
    delay(2000);
The state change detection example may have what you want. It shows how to detect changes (instead of levels). So the code can run just when the signal goes from 1 to 0 instead of is 0. And the change from 0 to 1 can be ignored.
Does this do what you want. It uses the method from the state change detection example.
int motor1pin1 = 2;
int motor1pin2 = 3;
int IRSensor = 4;
int Relay = 13;
int lastStatusSensor = 1;
   if (statusSensor != lastStatusSensor)
         delay(2000);
         delay(2000);
      lastStatusSensor = statusSensor;
