IR sensor stairs
I'm working on IR sensors stair projeck and now I trapped with programing.
what I want to build looks like this: SEQUA® Automatische LED-Treppenbeleuchtung (Sensorgesteuert) - Automatic LED stair-light controller - YouTube
but I want better with all posible ways.
I use 4 IR sensor like this: http://www.ebay.com/itm/Smart-Car-E18-D50NK-Infrared-Obstacle-Avoidance-Sensor-Proximity-Switch-3-50cm-/121320028394?pt=LH_DefaultDomain_0&hash=item1c3f3cb8ea
why 4 sensors? Because with 2 sensors I cant use all posible ways.
my vision about all posible ways:
1, 2, 3, 4 are sensors
red line is IR radius
brown line is how man cross IR radius
1 man cross nr1 radius
2 man cross both nr1 and nr2 radius
3 man cross only nr2 radius
4 man cross nr3 radius
5 man cross both nr3 and nr2 radius
6 man cross only nr2 radius
http://postimg.org/image/ay29uq3m5/
the same way is if man start using stairs from other side
http://postimg.org/image/7ys5g06ov/
I need 4 IR sensors to count people
http://postimg.org/image/7h1ldw6hr/
One man change his mind and turn back
http://postimg.org/image/kkb8c1wg1/
Both change minds and turn back
http://postimg.org/image/oocfe9lhf/
the same goes if they start using stairs whith other side
Next thing why I need to know how many people using staris and began to climb side is turn on LED's
If first man start using stairs from left:
Led1...Led2...Led3...Led4...ON
if first man start using staris from right:
Led4...Led3...Led2...Led1...ON
If last man finish using stairs to right:
Led1...Led2...Led3....Led4...OFF
If last man finish using staris to left:
Led4...Led3...Led2...Led1...OFF
here is my code:
//#include "Tlc5940.h"
const int s1=5;  //Sensor NR1
const int s2=4;  //Sensor NR2
const int s3=3;  //Sensor NR3
const int s4=2;  //Sensor NR4
int s1State=0;  //Sensor NR1 no active
int s2State=0;  //Sensor NR2 no active
int s3State=0;  //Sensor NR3 no active
int s4State=0;  //Sensor NR4 no active
int led1 =  50;
int led2 =  51;
int led3 =  52;
int led4 =  53;
int a=0;  //Sensor NR1 was activated
int b=0;  //Sensor NR2 was activated
int c=0;  //Sensor NR3 was activated
int d=0;  //Sensor NR4 was activated
int z=0;  //People count
int ledON=0;  //LED's are off
  //  Tlc.init();
  pinMode(s1, INPUT);
  pinMode(s2, INPUT);
  pinMode(s3, INPUT);
  pinMode(s4, INPUT);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
void loop(){
  s1State = digitalRead(s1);
  s2State = digitalRead(s2);
  s3State = digitalRead(s3);
  s4State = digitalRead(s4);
  //=====================================Vieno sensoriaus palietimas
  //=====================================First sensor active
  if(s1State==LOW && s2State==HIGH){
    a=1;
  if(s2State==LOW && s1State==HIGH){
    b=1;
  if(s3State==LOW && s4State==HIGH){
    c=1;
  if(s4State==LOW && s3State==HIGH){
    d=1;
  //=====================================Dveju sensoriu palietimas pradedant lipti
  //=====================================Two sensor active then start using stairs
  if(s1State==LOW && s2State==LOW && a==1){
    z=z+1;
    a=a+1;
  if(s4State==LOW && s3State==LOW && d==1){
    z=z+1;
    d=d+1;
  //=====================================Dveju sensoriu palietimas baigiant lipti
  //=====================================Two sensors active then finish using stairs
  if(s2State==LOW && s1State==LOW && b==1){
    z=z-1;
    b=b+1;
  if(s3State==LOW && s4State==LOW && c==1){
    z=z-1;
    c=c+1;
  //=====================================SAUGIKLIS
  //=====================================Fuse
  if(a==2 && b==1){
    a=0;
  if(b==2 && a==1){
    b=0;
  if(c==2 && d==1){
    c=0;
  if(d==2 && c==1){
    d=0;
  if(z<0){
    z=0;
  //=====================================Sviesa isijungia
  //=====================================LED's ON
  if(z==1 && ledON==0 && a==2){
    digitalWrite(led1, HIGH);
    digitalWrite(led2, HIGH);
    digitalWrite(led3, HIGH);
    digitalWrite(led4, HIGH);
    ledON = 1;
  if(z==1 && ledON==0 && d==2){
    ledON = 1;
  //=====================================Sviesa issijungia
  //=====================================LED's OFF
  if(z==0 && ledON==1 && c==2){
    digitalWrite(led1, LOW);
    digitalWrite(led2, LOW);
    digitalWrite(led3, LOW);
    digitalWrite(led4, LOW);
    ledON=0;
  if(z==0 && ledON==1 && b==2){
    ledON=0;
I dont know there is problem in code.
Dont know why but sensors LOW means that someone corss IR radius and HIGH means that no one corss IR radius
  if(s1==LOW && s2==HIGH){
    a=1;
And, if not, what value should a have?
  if(s1==LOW && s2==LOW && a==1){
    z=z+1;
    a=a+1;
The names a and z convey NO information. It is impossible to guess what this code is supposed to do.
  if(z=1 && ledON==0 && a==2){
Does this make sense? Why are there some = and some == in the same if statement?
You don't? It either does what you want, and there is not a problem, or it doesn't, and there is a problem.
Of course, what the code actually does is a mystery, and the pictures don't help with defining what you want. Sensors 1 and 2 are either at the top of the stairs, or they are at the bottom. They don't change location depending on which direction someone approaches the stairs from.
    a=1;
a = 0
z = 0
my mistake, it should look like this:
a = 0
z = 0
So, where is the code to make that happen?
or
int peopleCount; // Hey, look, no stupid comment needed.
in the beginning
All comments I write in my language and only now I put english comments
if you dont want to help me dont say nothing, I do not need your comments, which just wants to poke fun at
Cool project, hope you get it working.
My suggestion: Start with just one sensor and get it working and then move on to nd 2, then the 3rd , then the 4th sensor. Will make things musch easier for you.
Its not clear how close the sensors are. Make sure they don't interfere with each other!
Thanks, finaly work like I want to. I'm not a good programmer so code is not written in the best but it works, so now I have to improve code. Very helpful was Serial Monitor in arduino program, through Serial Monitor checks all variables step by step and find what was wrong. Earlier I wrote all variables in the paper and so make mistakes.
