Ir Sensor + Vibrating Pad
I have a school project that I am doing which is a sensing blind stick that will vibrate if there is an object in front of it. I have never used C++ and have only coded with python, so I don't have much of an idea of how this works. I am using an IR sensor, Arduino Nano microcontroller, and BestTong Mini vibrating pads. The code as of right now will only display a message about if there is an obstacle or not, and I found it online. How can I toggle the vibrating pad if it sees an object?
int isObstaclePin = A0; // This is our input pin
int isObstacle = HIGH; // HIGH MEANS NO OBSTACLE
pinMode(isObstaclePin, INPUT);
isObstacle = digitalRead(isObstaclePin);
if (isObstacle == LOW){
Serial.println("OBSTACLE!!, OBSTACLE!!");
else{
Serial.println("clear");
delay(200);
Thanks!
Please read the how to get the most from the forum post.
Please read the forum guidelines to see how to properly post code and some information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please go back and fix your original post
