IR sensor with 4x3 keypad matrix
My project is about a counter system. The counter is working based on user input by keypad matrix. I have write the coding but when i upload the coding, the counter does not incremented/decremented. But the led for receiver at the sensor working just fine. I tried to see the sensor data on serial monitor but there is no data at all. the sensor detect obstacle but serial monitor shows no data. can anyone help me check my coding and tell me what i do wrong?`
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
Show us a good schematic of your circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
#include <Keypad.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET    -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); //Declaring the display name (display)
const int ROW_NUM = 4; //four rows
const int COLUMN_NUM = 3; //three columns
char keys[ROW_NUM][COLUMN_NUM] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte pin_rows[ROW_NUM] = {9, 8, 7, 6};   //connect to the row pinouts of the keypad
byte pin_column[COLUMN_NUM] = {5, 4, 3}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM );
byte value = 0;
//----------- define IR
#define sensorPin1 2
#define sensorPin2 13
int sensorState1 = 0;
int sensorState2 = 0;
int count = 0;
int getNumber() {
  char key = keypad.getKey();
  switch (key) {
    case NO_KEY:
    case '*':
      display.clearDisplay();
      display.setTextColor(WHITE);
      display.setTextSize(1);
      display.setCursor(20, 0);
      display.print("Set counter: ");
      display.display();
      delay(200);
    case '0': case '1': case '2': case '3': case '4':
    case '5': case '6': case '7': case '8': case '9':
      value = value * 10;
      value = value + key - '0';
      display.println(value);
      display.display();
      delay(200);
    case '#':
      display.print("Counter is now set");
      display.setCursor(20, 10);
      display.print("THANK YOU");
      display.display();
      return (value);
      Serial.println(value);
void IRsensor() {
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x32)
  pinMode (sensorPin1, INPUT);
  pinMode (sensorPin2, INPUT);
  display.setCursor(0, 0);
  display.print("Press * to set counter");
  display.display();
  delay(200);
  getNumber();
  if (getNumber() == '#') {
    sensorState1 = digitalRead(sensorPin1);
    sensorState2 = digitalRead(sensorPin2);
    if (sensorState1 == LOW) {
      count++;
    if (sensorState2 == LOW) {
      count--;
    if (count <= 0)
      display.println("No visitors    ");
      display.display();
    else if (count > 0 && count < value) {
      display.setTextSize(4);
      display.println(count);
      display.display();
    else {
      display.setTextSize(2);
      display.println("FULL");
      display.setCursor(20, 20);
      display.println("PLEASE WAIT..");
      display.display();
can you please help me..
Why ignore the first number?
You will never see "value" printed because of the return.
Hello
insert several Serial.println() as logic analyser to see what happens inside sketch.
#include <Keypad.h>
#include <SPI.h>
#include <Wire.h>
boolean flag = false;
int visitor = 1;
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte pin_rows[ROW_NUM] = {11, 10, 9, 8};   //connect to the row pinouts of the keypad
byte pin_column[COLUMN_NUM] = {7, 6, 5}; //connect to the column pinouts of the keypad
byte value = 0;
#define sensorPin1 12
int count = 0;
int getNumber() {
  switch (key) {
    case NO_KEY:
    case '*':
      display.display();
      delay(200);
      value = value * 10;
      display.display();
      delay(200);
    case '#':
      flag = true;
      display.display();
      display.print("No visitor: ");
      display.display();
      return (value);
  display.display();
  delay(200);
  getNumber();
  if (flag == true) {
    flag = false;
    while (1) {
      if (sensorState1 == LOW && count != value) {
        Serial.println(sensorState1);
        count++;
      else if (count == value) {
        display.display();
      if (sensorState2 == LOW && count != 0) {
        count--;
        if (count == 0) {
          visitor = 0;
          display.display();
      else if (visitor == 0)
        display.display();
        display.display();
I have corrected my coding and it works just fine. but when i pressed '*' it does not goes back to the getNumber () function. can you tell me why and how to solve it?
#include <Keypad.h>
#include <SPI.h>
#include <Wire.h>
int visitor = 1;
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte value = 0;
int count = 0;
int getNumber() {
  switch (key) {
    case NO_KEY:
    case '*':
      display.display();
      delay(200);
      value = value * 10;
      display.display();
      delay(200);
    case '#':
      flag = true;
      display.display();
      display.display();
      return (value);
  display.display();
  delay(200);
  getNumber();
  if (flag == true) {
    flag = false;
    while (1) {
        count++;
        display.display();
        count--;
        if (count == 0) {
          visitor = 0;
          display.display();
        display.display();
        display.display();
'*' doesn't return a value from getNumber
so i need to add another if statement to go to the getNumber() function again is it?
i have done that and already succeed correcting that part of the coding. thank you sir :slight_smile:
When you introduced getNumber to the compiler, you promised that it would return an int value.
Look at how many cases you've got where it doesn't.
oh i see! i overlook that part! thank you so much :slight_smile:
