IR Sensor
Hello,
I am currently trying to use the Arduino Uno with an IR sensor and am currently only receiving readings like this...
0
1023
0
1023
etcetc
Does anyone have any suggestions as to why this might be?
Thank you!
What connections and code are you using??
Working Examples Here
A receiver like a TSOP of some variety can only give a 0 or 1 output, which is what you're getting if you read it on an analog pin.
In the presence of a carrier you get one value (the ones I've seen are active low, so the 0) and with no carrier, a 1 (or the 1023 analog).
Looks to me like it's working as advertised.
Yes. However any use which intends to get back what button was pushed uses a digital input and some code (usually a library) which decodes the series of pulses received.
terryking228:
OP didn't say anything about buttons and pulses (ie, a tv type remote). He might be just sending an unmodulated carrier.
In fact he didn't even say it's a tv remote type receiver: it might just be a high/low ir proximity sensor :wink:
As you asked:
.... along with hardware details. (Code as in tv remote code if applicable, AND code as in Arduino sketch)
