IR sensors and 4067 expansion
hi
im sensing the values from (currently) 5 ir sensors, and replaying that sensor reading to an led.
i want to expand my circuit to 16 leds and 16 ir sensors, so i’ve opted for the HEF4067 chip, which is quite well documented.
i have the test code running and this is fine, i can read from the 8 sensors i have currently wired in as i should be able to.
my issue is working this test code into my main code.
the main issue being that i the 4067 is read multiplexed, and im not sure how to use this data later.
most of the variable are setup to start
then in the setup, i take a 1 second calibration of the sensors, and then map this across the data range
in this i did have;
sensorValue1 = analogRead(A0);
but now i have
sensorValue1 = analogRead(readMux(0));
(which i know is wrong)
then in the main loop, i have the constant checking of the irs and the triggering of the leds.
can i get some pointers on the calibration loop, and the main loop with the 4067 code, or a way of breaking the 4067 code down to get better individual readings, like to change the
int readMux(int channel){
int controlPin = {s0, s1, s2, s3};
int muxChannel[16][4]={
{0,0,0,0}, //channel 0
{1,0,0,0}, //channel 1
to be more like;
int readMux(s0){0,0,0,0}
int readMux(s0){1,0,0,0}
(again, i know this code is wrong, but i can use the variable easier!)
etc.
Kelvin Mead
May 2013
Interactive LED panels
Design for 8 LEDs, 8 IR sensors and 8 IR Emitters
Addition for 4067, 16 channel input expander
// set up the leds on the pwm outputs
  int led1 = 5;
  int led2 = 6;
  int led3 = 9;
  int led4 = 10;
  int led5 = 3;
  int led6 = 11;
//Mux control pins
  int s0 = 2;
  int s1 = 4;
  int s2 = 7;
  int s3 = 8;
//Mux in "SIG" pin
  int SIG_pin = 0;
// fade speed
// 1 is instant, 9 is slow (not slow enough though)
  int fadespeed = 9;
  int ramp = 0;
// this is for changing the fade time without using the delay command
  long previousMillis = 0;
  // speed for the fades in milliseconds
  long interval = 25;
// lowest brightness setting (eliminates tiny flickering errors on divisable fades
  int lowestbrightness = 1;
// full brightness
  int maxBright = 255;
  //calibration routine
  int sensorValue1 = 0;         // the sensor value
// AND ALL THE VALUES IN BETWEEN << REDUCED FOR FORUM RULES
  int sensorValue8 = 0;         // the sensor value
  int sensorMin1 = 1023;        // minimum sensor value
  int sensorMin8 = 1023;        // minimum sensor value
  int sensorMax = 1000;         // maximum sensor value
// variables for high and low led
  int sensitivity = 10;
  int highsetting1 = 1000;
// initialize serial communication at 9600 bits per second:
// setup the leds as outputs
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  pinMode(led6, OUTPUT);
//  pinMode(led7, OUTPUT);
//  pinMode(led8, OUTPUT);
  int controlPin[] = {s0, s1, s2, s3};
    {0,1,0,0}, //channel 2
    {1,1,0,0}, //channel 3
    {0,0,1,0}, //channel 4
    {1,0,1,0}, //channel 5
    {0,1,1,0}, //channel 6
    {1,1,1,0}, //channel 7
    {0,0,0,1}, //channel 8
    {1,0,0,1}, //channel 9
    {0,1,0,1}, //channel 10
    {1,1,0,1}, //channel 11
    {0,0,1,1}, //channel 12
    {1,0,1,1}, //channel 13
    {0,1,1,1}, //channel 14
    {1,1,1,1}  //channel 15
  // turn on LED to signal the start of the calibration period:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  // calibrate during the first five seconds
  while (millis() < 1000) {
    sensorValue2 = analogRead(readMux(1));
    sensorValue3 = analogRead(readMux(2));
    sensorValue4 = analogRead(readMux(3));
    sensorValue5 = analogRead(readMux(4));
    sensorValue6 = analogRead(readMux(5));
    sensorValue7 = analogRead(readMux(6));
    sensorValue8 = analogRead(readMux(7));
    // record the minimum sensor value
    if (sensorValue1 < sensorMin1) {
      sensorMin1 = sensorValue1;
    if (sensorValue2 < sensorMin2) {
      sensorMin2 = sensorValue2;
    if (sensorValue8 < sensorMin8) {
      sensorMin8 = sensorValue8;
  // signal the end of the calibration period
  digitalWrite(13, LOW);
  // setup mux pins as outputs
  pinMode(s0, OUTPUT);
  pinMode(s1, OUTPUT);
  pinMode(s2, OUTPUT);
  pinMode(s3, OUTPUT);
// and set to low to initiate
  digitalWrite(s0, LOW);
  digitalWrite(s1, LOW);
  digitalWrite(s2, LOW);
  digitalWrite(s3, LOW);
// setup the ir sensors as inputs
  //loop through the 4 sig
  for(int i = 0; i < 4; i ++){
    digitalWrite(controlPin[i], muxChannel[channel][i]);
  //read the value at the SIG pin
  int val = analogRead(SIG_pin);
  //return the value
  return val;
  // read sensor values
  sensorValue2 = analogRead(readMux(0));
  sensorValue3 = analogRead(readMux(0));
  sensorValue4 = analogRead(readMux(0));
  sensorValue5 = analogRead(readMux(0));
  sensorValue6 = analogRead(readMux(0));
  sensorValue7 = analogRead(readMux(0));
  sensorValue8 = analogRead(readMux(0));
  // apply the calibration to the sensor reading
  int mappedValue1 = map(sensorValue1, sensorMin1, sensorMax, 0, 255);
  int mappedValue8 = map(sensorValue8, sensorMin8, sensorMax, 0, 255);
static int lastBright1 = 0;            // set the lastbright variable
if (mappedValue1<sensitivity) {                 // check to see if the ir is detecting above the base level
  analogWrite(led1, LOW);              // turn the led off
      if (lastBright1 > 0 && (currentMillis - previousMillis > interval))             // check to see if the last brightness is more than 0 and the interval time has passed
      lastBright1 = lastBright1/100*fadespeed;  // Dim the light til it reaches 0
}  else {
  lastBright1 = maxBright;                  //  Set the brightness to full
  if (lastBright1 < lowestbrightness) {              // check to see if the led has got to a low level
    lastBright1 = 0;                   // then turn the led off
  analogWrite(led1, lastBright1);      // write the brightness to the led
      if (lastBright1 > 0)
      lastBright1 = lastBright1/10*fadespeed;
}  else {
    lastBright1 = 0;
  static int lastBright2 = 0;
  if (mappedValue2<sensitivity) {
      if (lastBright2 > 0)
      lastBright2 = lastBright2/10*fadespeed;
}  else {
  lastBright2 = maxBright;
  if (lastBright2 < lowestbrightness) {
    lastBright2 = 0;
analogWrite(led2, lastBright2);
  static int lastBright3 = 0;
if (mappedValue3<sensitivity) {
      if (lastBright3 > 0)
      lastBright3 = lastBright3/10*fadespeed;
}  else {
  lastBright3 = maxBright;
  if (lastBright3 < lowestbrightness) {
    lastBright3 = 0;
analogWrite(led3, lastBright3);
  static int lastBright4 = 0;
  if (mappedValue4<sensitivity) {
      if (lastBright4 > 0)
      lastBright4 = lastBright4/10*fadespeed;
}  else {
  lastBright4 = maxBright;
  if (lastBright4 < 0) {
    lastBright4 = 0;
analogWrite(led4, lastBright4);
// THIS GOES ON FOR ANOTHER 4 LEDS / SENSORS BUT THE FORUM TEXT MAX IS 9500 CHARACTERS!
// delay for the crack of it
  delay(10);
Don't you just need to extract the bits from the channel number like this?
int readMux (int channel)
  digitalWrite (s3, channel & 8) ;
  digitalWrite (s2, channel & 4) ;
  digitalWrite (s1, channel & 2) ;
  digitalWrite (s0, channel & 1) ;
  return analogRead (A0) ;
i might have to, i don't understand what you've written there.
i've dropped it in my code, at the same point as
but i just get errors.
nope, im fighting with this for hours and hours...
i just can't put this code in any part of my code and make useful sense of it.
help :slight_smile:
MarkT:
ah ha, i've kinda worked this out now.
and its not something i've seen before, but the
lives outside the void loop ()
at the end. i get things running before, but never seen a slotted bit of code at the end of the program!?!
