IR Sensors
Hello community,
I have a problem with the communication between two arduinos through IR sensors.
in both arduinos I have two sensors one emitter and one receiver,
and I have to send a signal from Arduino A to arduino B, at first it works A sends and B receives, then B sends a signal back but A receives nothing,
after several tests I came to the conclusion that,
when the Arduino A sends a signal the receiver of the Arduino A stop working.
and this happens in the other arduino too
I use these libraries IRremote.h and IRremoteInt.h
Does anyone have a solution how to receive after sending ?
thank you
 #include <IRremote.h>
 #include <IRremoteInt.h>
 // int ledIR = 3;
  int PinIn = 4;
  int BPin = 2;
  int Data ;
IRsend isend;
IRrecv ir_recebe(PinIn);
decode_results codigo_recebido;
 // pinMode(ledIR ,OUTPUT);
  ir_recebe.enableIRIn();
  void loop(){
Serial.print("\n-------------------------------------------------------- ");
int val = digitalRead(BPin);
if (val== HIGH){
Start ();}
leData();
void Start(){
  delay (50);
  isend.sendNEC(0xAF0A, 32);//
  Serial.print("\nEnvia Codigo");
void leData (){
   Serial.print("\nFuncao Le data -> ");
     if (ir_recebe.decode(&codigo_recebido)) {
     if (codigo_recebido.value != 0 ){
      Serial.print("\nValor lido -> ");
      Serial.print(codigo_recebido.value, BIN);
      Data = codigo_recebido.value;
 ir_recebe.resume();
i found the solution, just need activate the Rx with this comand " ir_recebe.enableIRIn(); "
can close the topic
