IR serial link working, but with delay
I am making a project using a simple IR link connected to the serial ports of the 328 chip.
I have made a remote control that works well over a great distance ( I dont have to point it at the receiver, it bounces round the walls and is picked up )
The code I am using ( the poster didn’t put his name on it ) is :-
char buf [5];
char key;
int group = 0 ;
const byte numChars = 90;
char receivedChars[numChars];
boolean newData = false;
	Serial.begin(2400);
	Serial.println("<Arduino is ready -->");
	recvWithStartEndMarkers();
	showNewData();
	doOtherStuff(); // <<=== NEW  --- This just simulates time spent elsewhere in a big program
void recvWithStartEndMarkers() {
	static boolean recvInProgress = false;
	static byte ndx = 0;
	char startMarker = '<';
	char endMarker = '>';
	char rc;
	// if (Serial.available() > 0) {
	while (Serial.available() > 0 && newData == false) { // <<== NEW - get all bytes from buffer
		rc = Serial.read();
		if (recvInProgress == true) {
			if (rc != endMarker) {
				receivedChars[ndx] = rc;
				ndx++; //Serial.print(" ndx = ");Serial.println(int ( ndx ));
buf [ndx] =  rc;
				if (ndx >= numChars) {
					ndx = numChars - 1;
			else {
				receivedChars[ndx] = '\0'; // terminate the string
				ndx = 0;
				newData = true;
		else if (rc == startMarker) {
			recvInProgress = true;
void showNewData() {
	if (newData == true) {
		Serial.print("This just in ... ");
		Serial.println(receivedChars);
		newData = false;
grabkey ();
void doOtherStuff() {
	//   delay(20); // <<===NEW - This just simulates time spent elsewhere in a big program
I removed the delay in DoOtherstuff to get it fastest.
I have 5 buttons on the remote, and if I press a different button each time, it receives perfectly, but I cannot send the same button within a second or so.
I am using keypad.h in the remote, and the signal is coming out of the receiver ok, but I think it is the if (newData == true) part that makes it wait - perhaps letting another 90 chars come in ? ( I dont understand the code too well )
I want to be able to hold down a button and increment a counter at the receiver.
I have done this with VirtualWire in the past OK, but I cannot use that as I am using the timer to generate the 38 Khz carrier in the remote.
Any suggestions ?
( I am using v22 as I wanted to try Serialflush to deal with a hang up after it had been running a while, but I have disabled it for now, and willl use a watchdog later to flush after a few seconds of inactivity )
Boffin1: I am making a project using a simple IR link connected to the serial ports of the 328 chip.
The code I am using ( the poster didn't put his name on it ) is :-
 newData = false;
grabkey ();
Any suggestions ?
what is the grabkey()?
Chuck.
Hi Chuck
Its a routine that is going to check out the " password" which is SCORE, and the one character - either U, D, L, R, S for up, down, left, right, and store.
So far it is just :-
void grabkey() {
  if( (buf[1] =='S') &&  (buf[2] =='C') &&(buf[3] =='O') &&(buf[4] =='R') &&(buf[5] =='E') )
  { key = buf [6]; Serial.print("key in grabkey =  ");Serial.println(char ( key ));
for ( int J = 1; J <=6;J++ ) { buf [J] = 0 ;}  //  saved key , so clear buffer and serial buffer
//Serial.flush() ;
  Serial.println("test");
  }// END OF IF SCORE
} // end grabkey
I ditched the 38Khz timer generation, dead-bugged an ubiquitous 555 timer on the back of the minipro arduino, and am now using good old VirtualWire. :-)
It took 5 minutes, after hours of trying to get the original working !
