The information is overwhelming when searching this forum, but I still have a PWM problem.
I want to transmit IR signals. I have written two routines, one for setting up a PWM signal (38Khz) and an other for modulating this signal. I worked fine on an Arduino Uno, but there is a problem on the Mega 2560.
First setting up the PWM:
static void IR_PWM_INIT(void)
// Freq.=38Khz. Pulse is 26uSec. ATMega 16 ClockCyclesPerMicrosec. Period = (16 * 26)/2
#define top 207;
#define prescaler 1; // Clock niet laten delen door de prescaler. Dit is nit nodig voor deze frequentie
// PWM output OC2B (PMW-9 defined as output)
TCCR2A=0;
TCCR2B=0;
TCNT2=0; // Set counter to zero, fresh start.
ASSR&=~_BV(AS2); // clock is input for prescaler input:
OCR2B=top; // Set Output Compare register.
TCCR2A=_BV(WGM21); // CTC-mode: 010 = clear timer on compare match.
TCCR2B=prescaler; // 001 = No prescaling
Later I quickly turn on/of the PWM output to modulate the 38Khz signal
for(y=0; y<S.TransmitRepeat; y++) // herhaal verzenden IR code
x=1;
while(x<=RawSignal[0])
TCCR2B|=_BV(COM2B0); // turn PWM on
delayMicroseconds(RawSignal[x++]);
TCCR2B&=~_BV(COM2B0); // turn PWM off
It worked fine on a ATMega328, but no response on the ATMega2560.
Does anyone have an idea?
