ir sketch error: too few arguments to function 'void pulseIR(long int)'
i have only changed the ir pulses form the code on Making an Intervalometer | IR Sensor | Adafruit Learning System
but i am getting these error messages and i have no clue about wants worng can someone help me please
sketch_sep03c.ino: In function 'void SendNikonCode()':
sketch_sep03c:19: error: too few arguments to function 'void pulseIR(long int)'
sketch_sep03c:132: error: at this point in file
// This sketch will send out a Nikon D50 trigger signal (probably works with most Nikons)
// See the full tutorial at http://www.ladyada.net/learn/sensors/ir.html
// this code is public domain, please enjoy!
int IRledPin = 13; // LED connected to digital pin 13
// The setup() method runs once, when the sketch starts
  // initialize the IR digital pin as an output:
  pinMode(IRledPin, OUTPUT);
  Serial.println("Sending IR signal");
  SendNikonCode();
  delay(60*1000); // wait one minute (60 seconds * 1000 milliseconds)
// This procedure sends a 38KHz pulse to the IRledPin
// for a certain # of microseconds. We'll use this whenever we need to send codes
void pulseIR (long microsecs)
  // we'll count down from the number of microseconds we are told to wait
  cli(); // this turns off any background interrupts
  while (microsecs > 0)
    // 38 kHz is about 13 microseconds high and 13 microseconds low
    digitalWrite(IRledPin, HIGH); // this takes about 3 microseconds to happen
    delayMicroseconds(10); // hang out for 10 microseconds, you can also change this to 9 if its not working
    digitalWrite(IRledPin, LOW); // this also takes about 3 microseconds
    // so 26 microseconds altogether
    microsecs -= 26;
  sei(); // this turns them back on
void SendNikonCode() {
  // This is the code for my particular Nikon, for others use the tutorial
  // to 'grab' the proper code from the remote
  pulseIR(3780);
  delay(27);
  pulseIR(1560);
  delayMicroseconds(1000);
  pulseIR(720);
  delayMicroseconds(120);
  pulseIR(720);
  pulseIR(720);
  delayMicroseconds(140);
  pulseIR(700);
  delayMicroseconds(160);
  pulseIR(680);
  pulseIR(700);
  pulseIR(680);
  pulseIR(700);
  pulseIR(700);
  pulseIR(700);
  pulseIR(660);
  delayMicroseconds(180);
  pulseIR(660);
  delayMicroseconds(1060);
  pulseIR(660);
  delayMicroseconds(200);
  pulseIR(640);
  delayMicroseconds(220);
  pulseIR(560);
  delayMicroseconds(280);
  pulseIR(560);
  delayMicroseconds(300);
  pulseIR(560);
  pulseIR(560);
  pulseIR(560);
  pulseIR(560);
  pulseIR(540);
  delayMicroseconds(320);
  pulseIR(520);
  delayMicroseconds(1180);
  pulseIR(520);
  pulseIR(520);
  delayMicroseconds(340);
  pulseIR(500);
  pulseIR(500);
  delayMicroseconds(360);
  pulseIR(480);
  delayMicroseconds(380);
  pulseIR(460);
  pulseIR(480);
  pulseIR(460);
  delayMicroseconds(1220);
  pulseIR(480);
  pulseIR(480);
  pulseIR(480);
  delayMicroseconds(1240);
  pulseIR(460);
  pulseIR(480);
  pulseIR(460);
  pulseIR(460);
  pulseIR(480);
  pulseIR(460);
  pulseIR(480);
  pulseIR(460);
  pulseIR(80);
  pulseIR(480);
  pulseIR(460);
  pulseIR(480);
  pulseIR();
  pulseIR();
Doesn't look like the right number of arguments to me.
thankyou!!!!!!!!
i was look at that code for an hour and didnt notice
In case you hadn't realised, this is telling you that the error is at line 132 in the source code file.
The place where the compiler realises that there is an error, isn't always exactly where the error really is,
but it is a good place to start looking.
