Hello all,
So I nearly have the code working the way I want it to. However, how would I be able to have the automatic mode on the loop forever unless I press the same button I used to turn on automatic mode? A bit like a toggle switch on or off?
Code below:
#include "IRremote.h"
#include<NoDelay.h>
/*-----( Declare Constants )-----*/
int IR = 4; // pin 1 of IR receiver to Arduino digital pin 11
int LEDACT = 3; // LED activity
int RELAY = 6; // RELAY
//int voltage = 0.50 ;
// Flashing LED with photo
void ledBlink();//Must declare function before noDelay
noDelay LEDtime(1, ledBlink);//Creats a noDelay varible set to 1000ms, will call ledBlink function
int LEDpin = 2;
int ledState = LOW;
/*-----( Declare objects )-----*/
IRrecv irrecv(IR); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
/*--------- delays -----*/
const unsigned long delay_1h30 = 5400000; // 1h30 to ms is 5400000
const unsigned long delay_12h = 43200000; // 12h to ms is 43200000
const unsigned long interval = 1; // 1000Hz
const unsigned long interval1 = 10000; // read voltage every 1 second
unsigned long previousMillis = 0;
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
unsigned long previousMillis3 = 0;
unsigned long lastStateChangeMillis = currentMillis;
/* ------ PHOTO --------*/
// int sensorValue = analogRead(A0);
// float voltage = sensorValue * (5.0 / 1023.0);
// FUNCTION FOR FLASH
void ledBlink()
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(LEDpin, ledState);
void setup() /*----( SETUP: RUNS ONCE )----*/
Serial.println("Snow detector");
irrecv.enableIRIn(); // Start the receiver
pinMode(LEDACT, OUTPUT);
pinMode(LEDpin, OUTPUT);
pinMode(RELAY, OUTPUT);
digitalWrite(RELAY, LOW);
}/*--(end setup )---*/
void loop(){ /*----( LOOP: RUNS CONSTANTLY )----*/
Serial.println(voltage);
LEDtime.fupdate();//will check if set time has past and if so will run set function
if (irrecv.decode(&results)) // have we received an IR signal?
// Serial.println(results.value, HEX); UN Comment to see raw values
translateIR();
irrecv.resume(); // receive the next value
}/* --(end main loop )-- */
/*-----( Declare User-written Functions )-----*/
void translateIR() // takes action based on IR code received
switch(results.value)
case 0xFFA25D:
Serial.println(" TOGGLE RELAY ON ");
digitalWrite(LEDACT, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LEDACT, LOW); // turn the LED off by making the voltage LOW
digitalWrite(RELAY, HIGH);
case 0xFFE21D:
Serial.println(" 1h30 ");
for (int i = 0; i <= 2; i++) {
Serial.println(" RELAY ON");
delay(10000); //1h30
Serial.println(" RELAY OFF");
case 0xFF22DD:
Serial.println(" 12h ");
for (int i = 0; i <= 3; i++) {
delay(10000); //12 hour
case 0xFF02FD:
Serial.println(" TOGGLE RELAY OFF ");
delay(250); // wait for a second
delay(250);
case 0xFF629D:
Serial.println(" Automatic mode ");
if (voltage > 1.00) {
delay(10000);
default:
Serial.println(" other button ");
} //END translateIR
