IR transmission
Hello everyone.
I saw some topics about sending/receiving IRs and tried to test it. Through pulseIn(), I successfully received the IRs, but the problem I'm having is to send them back. I don't know anything about how to do it. I'm using an QED234 for IR transmission, and my question is: how do I know what delayMicroseconds() I should use when "sending pulses".
Sorry if I said something wrong, I really need some clarification.
Thanks in advance.
I generally prefer to "get my hands dirty". I generally avoid libraries. But I have to "be weak" once in a while, and boy am I pleased I went the "library" route for communicating with IR signals.
I assume you are talking about using, or simulating, the everyday "domestic", much derided "remote control", latter word a noun, not verb, as in the one for changing the TV's channel?
If so, see....
http://sheepdogguides.com/arduino/ar3ne1ir.htm
(You don't need the specific sensor or shield mentioned there to benefit from the material in it.)
Thanks, tkbyd. I will try it.
That library is awesome, I've used it before. With one 38kHz IR Receiver Module, a resistor and an IR LED you can capture and send IR pulses in half an hour.
For how-to instructions on capturing pulses; http://www.instructables.com/id/Fart-Operated-Random-Channel-TV-Remote/step2/Getting-Pulse-Codes-from-your-TV-Remote/
For how-to instructions on cleaning up IR pulses (if your protocol isn't recognized and you need to use raw pulses); http://www.instructables.com/id/Fart-Operated-Random-Channel-TV-Remote/step3/Clean-up-your-Pulse-Codes/
and for how-to instructions (and code you can download and modify to your needs) on sending IR pulses; http://www.instructables.com/id/Fart-Operated-Random-Channel-TV-Remote/step4/Test-Your-Remote/
