Hi, I am making a simple IR transmitter using infrared LED. I am able to generate simple PWM but I want PWM for specific bit. For example I want send 10010100 how should I generate manchester (0r any other easy bit encoding scheme). Here is my simple code using key denouncing.
int pinout = 12; int pinout_pwm = 9;
boolean send_pulse =false; void setup() { pinMode(pinout, OUTPUT); pinMode(pinout_pwm, OUTPUT); pinMode(3, OUTPUT); pinMode(11, OUTPUT); attachInterrupt(0, check_event, FALLING); Serial.begin(9600);
void loop() { if(send_pulse) { digitalWrite(pinout, HIGH);
Serial.println("One pulse send"); pinMode(3, OUTPUT); TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM21) | _BV(WGM20); TCCR2B = _BV(CS22); OCR2A = 110; OCR2B = 110; send_pulse = false; delay(8); pinMode(3, INPUT); //generate_PWM();
digitalWrite(pinout, LOW); }
void check_event()//Interrupt service routine {
send_pulse = true; }
Any help would really be appreciated. Thank you very much.
