IR transmitter not working with Arduino
I was able to fix the problem. Thanks for all the help.
The problem was with the code and after some searching the code below is what got me the results I was looking for.( The IR led transmits the code)
 * SimpleSender.cpp
 *  Demonstrates sending IR codes in standard format with address and command
 *  An extended example for sending can be found as SendDemo.
 *  Copyright (C) 2020-2021  Armin Joachimsmeyer
 *  armin.joachimsmeyer@gmail.com
 *  This file is part of Arduino-IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
 *  MIT License
#include <Arduino.h>
 * Define macros for input and output pin etc.
#include "PinDefinitionsAndMore.h"
//#define SEND_PWM_BY_TIMER
//#define USE_NO_SEND_PWM
#include <IRremote.h>
IRsend irsend;
int i = 0;
    pinMode(LED_BUILTIN, OUTPUT);
    // Just to know which program is running on my Arduino
    Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
     * The IR library setup. That's all!
    IrSender.begin(IR_SEND_PIN, ENABLE_LED_FEEDBACK); // Specify send pin and enable feedback LED at default feedback LED pin
    Serial.print(F("Ready to send IR signals at pin "));
    Serial.println(IR_SEND_PIN);
   if (i == 0){
    irsend.sendNEC(0xFF02FD, 32); // this turns on the led strip
    i++;
   else{
    irsend.sendNEC(0xFF1AE5, 32); // this selects the colour red
