IR trouble
I have created a program where 2.wav is played as soon as the Ir sensor on pin 3 senses something but even when it senses something, it doesn`t play 2.wa and nor do the lights operate in the manner they are supposed to.
1.wav is, however, getting played.
The code is:
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#define SD_ChipSelectPin 4
TMRpcm tmrpcm;
pinMode (2,OUTPUT);
pinMode (3,INPUT);
pinMode (7,OUTPUT);
pinMode (8,OUTPUT);
SD.begin(4);
tmrpcm.speakerPin = 9;
int diw=0;
digitalWrite (7,HIGH);
delay(2000);
digitalWrite (7,LOW);
delay(2000);
Serial.println(“initialization done.”);
if (!SD.begin(4)) {
digitalWrite (8,HIGH);
Serial.println(“SD NOT FOUND, Please Insert.”);
Serial.println(“SD FOUND”);
digitalWrite (7, LOW);
delay(3000);
tmrpcm.setVolume(7);
tmrpcm.play(“1.wav”);
Serial.println(“FILE FOUND”);
return;
if(digitalRead(3)== HIGH){
Serial.println(“You are ready for your song.”);
tmrpcm.play(“2.wav”);
digitalWrite (8,LOW);
digitalWrite (2,HIGH);
digitalWrite (2,LOW);
Serial.println(“Come close to the system, Mumma”);
delay(15000);
digitalWrite(8,LOW);}
Does pin 3 ever go HIGH ?
Why keep initialising the SD in loop() ?
What do you see on the Serial monitor ?
You are using INPUT instead of the more common INPUT_PULLUP. This works only if you have pullup resistors, pulldown resistors, or something that properly drives the input. How do you have things wired? Where is your wiring diagram?
