IRA-S210ST01 PIR sensor
Hi
I am playing about with a IRA-S210ST01 PIR sensor.
I was hoping this would connect directly to a processor (with a few setup component).
But, seem to do nothing. I am guessing the output is so small, that I need to amplify it?
The test setup on the page above just shows a 47k pulldown and a 22uf going to an amplifier to test on an oscilloscope.
So... I need an amp etc
https://www.farnell.com/datasheets/2199767.pdf
So, can someone tell me the difference between the demo circuits 'Source voltage' and 'White noise'?
Don't have any LM224 OP-Amps here, but I do have a pile of LM324's
Made the source voltage circuit with an LM358. I see no change in output at all on my multimeter (don't have a scope).
Would have expected to see at least some change
Clearly wrong!
Did you use a Fresnel lens.
Leo..
You won't. You need a scope.
Basically the same.
Yes. I have a Fresnel lens on it.
How can I get an output from this PIR that I can feed into a processor?
I understood from research (now looking incorrect) that the output needed minimal processing (unlike other PIR sensors)
I thought an LM358 would have worked.
Oh well
see post #5
Use the circuit in the datasheet.
Brilliant
I'll try this one
The signal at the point with the red arrow will still be very small, maybe a couple of hundred millivolts with a DC offset.
A HCSR501 PIR sensor modele is cheap, has the same sensor in it with a special BISS0001 chip.
Why build it yourself.
Leo..
Because its going on a bespoke PCB... no room for a larger PIR module
The AM312 is smaller.
Leo..
