IRF520 MOSFET Driver Module(or similar)
Hello,
I wonder if there is such a MOSFET module which at the same time can power my arduino? So I want to power a led with a battery and want to use the mosfet as a switch, but since the led needs a higher voltage and I need to use a boost converter I don't know how to power the arduino (nano)... Does anyone has a solution for me?
Thank you!
Kind regards
The IRF520 is not a logic level MOSFET, and will work poorly, or not at all with Arduino.
Either use a logic level MOSFET or an NPN bipolar transistor as a switch. This is a typical MOSFET circuit:
I cannot for the life of me comprehend what the pinout of a 2N7000 is doing on that diagram or how it could possibly be in any way relevant! :astonished:
