Hi
I've followed this (Sending IR Codes | Using an Infrared Library on Arduino | Adafruit Learning System) tutorial as I'm trying to replace an IR remote with an Ardunio Uno to control an RGB LED floodlight.
The floodlight came with a standard 24 button remote and I've been able to read the codes with the IRLib library as explained in the above tutorial.
The result of the serial monitor for the code I want the arduino to send is:
eady to receive IR signals
Decoded NEC(1): Value:F720DF Adrs:0 (32 bits)
Raw samples(68): Gap:5966
Head: m9102 s4542
0:m538 s598 1:m542 s598 2:m542 s598 3:m542 s602
4:m542 s598 5:m542 s598 6:m542 s598 7:m542 s602
8:m542 s1706 9:m542 s1710 10:m542 s1710 11:m542 s1710
12:m542 s598 13:m546 s1706 14:m542 s1710 15:m542 s1710
16:m542 s598 17:m546 s594 18:m546 s1706 19:m546 s598
20:m542 s598 21:m546 s594 22:m546 s598 23:m542 s598
24:m546 s1706 25:m542 s1710 26:m542 s602 27:m542 s1706
28:m546 s1710 29:m542 s1706 30:m546 s1706 31:m546 s1706
32:m542
Extent=67354
Mark min:538 max:546
Space min:594 max:1710
I'm really struggling to get this code to send from the Arduino - is anyone able to advise on the code please? I have the IR transmitter LED connected to pin 2.
Many thanks
