While delay takes place, is an IRQ buffered? that is, once it exits out of ‘delay(1000)’ for example , if at 555ms in, would if an interrupt triggered, get placed in a queue?
if not, I may need to drop Delay and switch to milli,and or leave in a small delay 50ms or so (i’m taking temperature measurements and I really don’t want to have a relay oscillating that quickly if I accidentally introduced a bug, so the delay is purely protection) (only needed a delay to so i can debug it via serial) …
Because it’s happy to wait 1.25 seconds per reading from the dallas sensor, i’m happy, the relay’s happy, speed is not important at all, I think 1 second is a little quick lol
#include <OneWire.h>
#include <stdlib.h>
#include <DallasTemperature.h>
#include <Wire.h>
//#include <Wire.h>
//#include <Adafruit_BMP085.h>
#define RelayPin 2
#define Rled 3
#define Gled 5
#define Bled 6
boolean Relay = false;
boolean RelayM = false;
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 10
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
LiquidCrystal_I2C lcd(0x27,16,2);
DallasTemperature sensors(&oneWire);
void setup(void)
// start serial port
pinMode(Rled,OUTPUT);
pinMode(Gled,OUTPUT);
pinMode(Bled,OUTPUT);
pinMode(RelayPin,OUTPUT);
pinMode(8,INPUT);
analogWrite(Rled,0);
analogWrite(Gled,0);
analogWrite(Bled,0);
for (int i=1; i<10; i++) //3 pin RGB test
analogWrite(Rled,225);
delay(20);
delay(20);
analogWrite(Gled,225);
delay(20);
delay(20);
analogWrite(Bled,225);
delay(20);
delay(20);
lcd.init(); // initialize the lcd
lcd.backlight();
// Print a message to the LCD.
/* for (int n=1; n<55;)
n++;
lcd.backlight();
delay(100);
lcd.noBacklight();
delay(100);
Serial.println("Dallas Temperature IC Control Library Demo");
// if (!bmp.begin())
// Serial.println("Could not find a valid BMP085 sensor, check wiring!");
// Start up the library
sensors.begin();
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Dallas - Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
lcd.setCursor(0,0);
lcd.print("The Temperature:");
float T;
char TStr[5];
// T= 21;
// Serial.println(T);
T = sensors.getTempCByIndex(0);
if (T<10) //this is for a quick visual status
//relay on, heater on.
Serial.println("freezing cold");
analogWrite(Bled,220);
if ((T>=10) &(T<19))
Serial.println("cold");
if ((T>=19) & (T<26))
Serial.println("warm");
if ((T>=26) & (T<40))
Serial.println("hot");
//pin 8 connects to a button to override and turn on the heater
//ideally, I want to trigger this quicker, so a delay may have to go
if (digitalRead(8)==HIGH)
RelayM=!RelayM;
digitalWrite(RelayPin,RelayM);
if (RelayM==true) //button press detected (although holding down is required depends on luck)
if (T>=22.00) //max temp to reach with override button
RelayM=false;
} //heater off
if (T>=20.00 & RelayM==false) //if override is off do normal operation
Relay=false; //turn off relay
digitalWrite(RelayPin,Relay);
} //heater off
if (T<=18.00)
Relay=true; //turn on relay as it's cold
dtostrf(T,5, 3, &TStr[0]);
TStr[5]=0;
lcd.setCursor(0,1);
Serial.println(TStr);
lcd.print(TStr);
lcd.println(" Degrees C ");
delay(1250);
lcd.clear(); //i2c library LCD
//was hooked up to a Barometer/Temp sensor, not needed.
/* Serial.println("");
Serial.println("Barometer / Temp info");
Serial.println("");
Serial.print("Temperature = ");
Serial.print(bmp.readTemperature());
Serial.println(" *C");
Serial.print("Pressure = ");
float pr;
pr = (bmp.readPressure()/100)+ 9.5;
Serial.print(pr);
Serial.println(" hPa");
// Calculate altitude assuming 'standard' barometric
// pressure of 1013.25 millibar = 101325 Pascal
Serial.print("Altitude = ");
Serial.print(bmp.readAltitude());
Serial.println(" meters");
delay(1250);
// you can get a more precise measurement of altitude
// if you know the current sea level pressure which will
// vary with weather and such. If it is 1015 millibars
// that is equal to 101500 Pascals.
Serial.print("Real altitude = ");
Serial.print(bmp.readAltitude(101500));
So any suggestions? drop the delay? or not worth the bother (i don’t mind holding down the button lol)
