Irradiation meter with arduino
hello everyone , my project is irradiation meter (w/m2). i have to use opt101 so i will use cjmcu-101 sensor. i am beginner level for codding so i search about this project in internet and found same project in this website (DIY Irradiation Meter with Arduino – A blog about DIY solar and arduino projects). but in this website they use different materials fo project.Will it work if I use the code from this site? do i need to change the code?
here is the code
        /* 0- General */
        int decimalPrecision = 2;                   /* decimal places for only for current value shown in LED Display */
        /* 1- DC Current & Irradiation */
        int CurrentAnalogInputPin = A1;             // Which pin to measure Current Value
        float mVperAmpValue = 120;                  // If using ACS712 current module : for 5A module key in 185, for 20A module key in 100, for 30A module key in 66
                                                    // If using WCS current module : for 0.25A module key in 7000, for 0.5A module key in 3500, for 1.0A module key in 2000, for 2.0A module key in 1000.
        float moduleMiddleVoltage = 2500;           // key in middle voltage value in mV. For 5V power supply key in 2500, for 3.3V power supply, key in 1650 mV
        float moduleSupplyVoltage = 5000;           // supply voltage to current sensor module in mV, default 5000mV, may use 3300mV
        float currentSampleRead  = 0;               /* to read the value of a sample*/
        float currentLastSample  = 0;               /* to count time for each sample. Technically 1 milli second 1 sample is taken */
        float currentSampleSum   = 0;               /* accumulation of sample readings */
        float currentSampleCount = 0;               /* to count number of sample. */
        float currentMean ;                         /* to calculate the average value from all samples*/
        float finalCurrent ;                        /* the final current reading without taking offset value*/
        float finalCurrent2 ;                       /* the final current reading*/
        float ShortCircuitCurrentSTC = 4.5  ;      // Key in the Short Circuit Current (At STC condition) of your Solar Panel or Solar Cell. Value 9 showing 9.0A Isc Panel.
        float Irradiation = 0.00;                   /* This shows the irradiation level in W/m2.
            /* 1.1 - Offset DC Current */
            int   OffsetRead = 0;                   /* To switch between functions for auto callibation purpose */
            float currentOffset =0.00;              // to Offset deviation and accuracy. Offset any fake current when no current operates.
                                                    // the offset will automatically done when you press the <SELECT> button on the LCD display module.
                                                    // you may manually set offset here if you do not have LCD shield
            float offsetLastSample = 0;             /* to count time for each sample. Technically 1 milli second 1 sample is taken */
            float offsetSampleCount = 0;            /* to count number of sample. */
            /* 1.2 - Average Accumulate Irradiation */
            float accumulateIrradiation = 0;                          /* Amount of accumulate irradiation*/
            unsigned long startMillisIrradiation;                     /* start counting time for irradiation energy */
            unsigned long currentMillisIrradiation;                   /* current counting time for irradiation energy */
            const unsigned long periodIrradiation = 1000;             // refresh every X seconds (in seconds) Default 1000 = 1 second
            float FinalAccumulateIrradiationValue = 0;                /* shows the final accumulate irradiation reading*/
        /* 2 - LCD Display  */
        //#include<LiquidCrystal.h>                                   /*Load the liquid Crystal Library (by default already built-it with arduino solftware)*/
        //LiquidCrystal LCD(8,9,4,5,6,7);                             /*Creating the LiquidCrystal object named LCD */
        LiquidCrystal_I2C LCD(0x27, 16, 2);
        unsigned long startMillisLCD;                               /* start counting time for LCD Display */
        unsigned long currentMillisLCD;                             /* current counting time for LCD Display */
        const unsigned long periodLCD = 1000;                       // refresh every X seconds (in seconds) in LED Display. Default 1000 = 1 second
        /* 0- General */
        Serial.begin(9600);                               /* In order to see value in serial monitor */
        startMillisIrradiation = millis();                /* Record initial starting time for daily irradiation */
        //LCD.begin(16,2);                                  /* Tell Arduino that our LCD has 16 columns and 2 rows*/
        LCD.begin();
        LCD.setCursor(0,0);                               /* Set LCD to upper left corner to start display*/
        startMillisLCD = millis();                        /* Record initial starting time for LCD Display refresh rate. */
  /* 0.1- Button Function */
              int buttonRead;
              buttonRead = analogRead (0);                                    // Read analog pin A0. By default the LCD Display shield already assigned A0 as button function. Cannot change.
              /*Right button is pressed */
              if (buttonRead < 60)
              {   LCD.setCursor(0,0); LCD.print ("PRESS <SELECT>   ");      }
              /* Up button is pressed */
              else if (buttonRead < 200)
              /* Down button is pressed */
              else if (buttonRead < 400)
              /* Left button is pressed */
              else if (buttonRead < 600)
              /* Select button is pressed */
              else if (buttonRead < 800)
              OffsetRead = 1;                                                 // to activate offset when button <SELECT> is pressed
              LCD.setCursor(0,0);
              LCD.print ("INITIALIZING..... ");
              LCD.setCursor(0,1);
              LCD.print ("WAIT 5 SEC ..... ");
        if(millis() >= currentLastSample + 1 )        /* every 1 milli second taking 1 reading */
            currentSampleRead = analogRead(CurrentAnalogInputPin)-((moduleMiddleVoltage/moduleSupplyVoltage)*1024);      /* read the sample value */
            currentSampleSum = currentSampleSum + currentSampleRead ;                                         /* accumulate value with older sample readings*/
            currentSampleCount = currentSampleCount + 1;                                                      /* to move on to the next following count */
            currentLastSample = millis();        /* to reset the time again so that next cycle can start again*/
        if(currentSampleCount == 1000)        /* after 1000 count or 1000 milli seconds (1 second), do the calculation and display value*/
            currentMean = currentSampleSum/currentSampleCount;                                                /* calculate average value of all sample readings taken*/
            finalCurrent = (((currentMean /1024)*moduleSupplyVoltage)/mVperAmpValue);                         /* calculate the final current (without offset)*/
            finalCurrent2 = finalCurrent+currentOffset;                                                       /* The final current */
            Irradiation = (finalCurrent2/ShortCircuitCurrentSTC*1000);
            Serial.print(finalCurrent2,decimalPrecision);
            Serial.print(" A  ");
            Serial.print(Irradiation,decimalPrecision);
            Serial.print(" W/m2  ");
            currentSampleSum =0;        /* to reset accumulate sample values for the next cycle */
            currentSampleCount=0;        /* to reset number of sample for the next cycle */
            if(OffsetRead == 1)
                currentOffset = 0;                                                             /* set back currentOffset as default first*/
                if(millis() >= offsetLastSample + 1)                                           /* offset 1 - to centralise analogRead waveform*/
                    offsetSampleCount = offsetSampleCount + 1;
                    offsetLastSample = millis();
                   if(offsetSampleCount == 2500)                                             /* need to wait awhile as to get new value before offset take into calculation.  */
                {        /* So this code is to delay 2.5 seconds after button pressed */
                  currentOffset = - finalCurrent;                                             /* to offset values */
                  OffsetRead = 0;                                                             /* until next offset button is pressed*/
                  offsetSampleCount = 0;                                                      /* to reset the time again so that next cycle can start again */
                  LCD.setCursor(0,0);
                  LCD.print ("OFFSET.....     ");
                  LCD.setCursor(0,1);
                  LCD.print ("DONE  .....     ");
         currentMillisIrradiation = millis();        /* Count the time for current */
        if (currentMillisIrradiation - startMillisIrradiation >= periodIrradiation)
            accumulateIrradiation = Irradiation/3600*(periodIrradiation/1000);                                /* for smoothing calculation*/
            FinalAccumulateIrradiationValue =  FinalAccumulateIrradiationValue + accumulateIrradiation ;
            Serial.print(FinalAccumulateIrradiationValue,decimalPrecision);
            Serial.println(" Wh/m2/day");
            startMillisIrradiation = currentMillisIrradiation ;                                               /* Set the starting point again for next counting time */
        currentMillisLCD = millis();
        if (currentMillisLCD - startMillisLCD >= periodLCD)
            LCD.setCursor(0,0);        /* Set cursor to first colum 0 and second row 1  */
            LCD.print(finalCurrent2,decimalPrecision);                                                    /* display voltage value in LCD in first row  */
            LCD.print(" A   ");
            LCD.setCursor(8,0);
            LCD.print(Irradiation,0);        /* display current value in LCD in first row */
            LCD.print(" W/m2   ");
            LCD.setCursor(0,1);
            LCD.print(FinalAccumulateIrradiationValue,0);                                                 /* display current value in LCD in first row */
            LCD.print(" Wh/m2/day        ");
            startMillisLCD = currentMillisLCD ;                                                           /* Set the starting point again for next counting time */
I'd say that code has a pretty strong anti-plagiarism signature.
Are you sure you want to use that?
How would that be possible to answer, without knowing anything about the "different materials"?
You need this link: How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
The code does not have to be nearly that complicated. Here is another good site: Measuring Sunlight at Earth’s Surface: Build Your Own Pyranometer
OP seems to be using a cjmcu-101, which is a photodiode with integrated transimpedance amplifier. The posted code for a solar cell with an ACS712 is useless.
Just power the sensor with 5volt from the Uno,
and connect sensor output to an analogue pin.
See what values you get with an analogRead.
Leo..
solar cell with an ACS712 current module
Your project is fundamentally simple. You only need to make measurements, and scale them to some familiar representation of the input. You can do that part with some experimentation and calibration against known sources (e.g. sunlight). The code itself will be so simple, that copying someone else's sketch, makes it 10 times harder than writing it yourself.
You can just ditch the elaborate framework in that code, and write a much simpler interface. You don't need all those frills.
Confused.
Are you using a solar cell with ACS712,
or are you using a cjmcu-101, as you mention in your first post.
A cjmcu-101 is not a solar cell. It can't be use with an ACS712.
Leo..
i am using just cjmcu-101. sorry about that i was should be more descriptive.I just started learning to code so i just wanted to ask this code work or not. probably i need new code for using with cjmcu-101. anyway thank you all for your answers
You should have shown a connection diagram, to stop confusion. You still can.
The code and the article you linked to are not relevant to the sensor you have.
Always start simple. Try this sketch and see what values you get in the serial monitor.
Leo..
const byte sensorPin = A0;
int sensorValue;
  sensorValue = analogRead(sensorPin);
  Serial.println(sensorValue);
How have you connected the solder pads on the back of the PCB?
Looks like you forgot to connect V- and COM. Try the the connection scheme shown here: https://www.electroschematics.com/photodiode/
That link was already in post#6.
Leo..
no i did not connected any solder pads
when light is open, sensor gives me value maximum 866. What value does this data represent?
Ekran görüntüsü 2023-03-28 163008
I’d say it’s time to start talking about your application. Is this just a school project or do you have an actual use in mind?
How you calibrate your device will depend on what you want to use it for.
school project
Maybe if you post the text of the assignment, someone can suggest how to calibrate it.
(device that can measure intensity of sunlight in Watt per meter square (w/m2) and arduino must be used.)
