Hi all,
My IR reciever works well until I call one of the "analogWrite" commands with anything less than 255, after that the IR code nolonger works and all commands come through as protocol UNKNOWN.
I used the SimpleReciever code from the IRRemote library, and used an L298N motor controller with an external 12v power supply. I'll try and find out how to show a cuircit diagram, but I am reasonably comfortable the power is correct and there's a shared earth. The Arduino Uno R3 is powered by USB.
If I comment out the analogueWrite commands, the code continues to receive and process good IR commands. If I introduce the analogueWrite commands and call one with say analogueWrite(235), following that all the IR commands just come through as protocol UNKNOWN.
Any guidence is greatly received. Code is below.
#define DECODE_NEC // Includes Apple and Onkyo
#include <Arduino.h>
#include <IRremote.hpp>
#define enA 11
#define in1 12
#define in2 13
#define enB 6
#define in3 7
#define in4 8
#define irPin 9
int wheelPower = 255;
int wheelDuration = 200;
int turnDuration = 20;
// Just to know which program is running on my Arduino
Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
// Start the receiver and if not 3. parameter specified, take LED_BUILTIN pin from the internal boards definition as default feedback LED
IrReceiver.begin(irPin, ENABLE_LED_FEEDBACK);
Serial.print(F("Ready to receive IR signals of protocols: "));
printActiveIRProtocols(&Serial);
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
setDirection(0); //default to forward
// Set the pins for direction
// 0=forward, 1=backwards
void setDirection(int direction){
if(direction == 0){
//forward
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
}else{
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
if (IrReceiver.decode()) {
// Print a short summary of received data
//IrReceiver.printIRResultShort(&Serial);
//IrReceiver.printIRSendUsage(&Serial);
if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
Serial.println(F("Received noise or an unknown (or not yet enabled) protocol"));
// We have an unknown protocol here, print more info
IrReceiver.printIRResultRawFormatted(&Serial, true);
//Serial.println();
* !!!Important!!! Enable receiving of the next value,
* since receiving has stopped after the end of the current received data packet.
IrReceiver.resume(); // Enable receiving of the next value
irCommand = IrReceiver.decodedIRData.command;
* Finally, check the received data and perform actions according to the received command
if (irCommand == 0x46) {
//Serial.println("received vol+");
Serial.println("Drive Forward");
setDirection(0);
analogWrite(enA, wheelPower);
analogWrite(enB, wheelPower);
delay(300);
analogWrite(enA, 0);
analogWrite(enB, 0);
} else if (irCommand == 0x15) {
//Serial.println("received vol-");
Serial.println("Drive Backward");
setDirection(1);
delay(300);
}else if (irCommand == 0x44) {
//Serial.println("received L");
Serial.println("Drive LEFT");
}else if (irCommand == 0x43) {
//Serial.println("received R");
Serial.println("Drive RIGHT");
}else if (irCommand == 0x18) {
Serial.println("received 2");
wheelPower -=10;
if(wheelPower < 3){
wheelPower = 3;
Serial.print("Power");
Serial.println(wheelPower);
}else if (irCommand == 0x5E) {
Serial.println("received 3");
wheelPower +=10;
if(wheelPower > 255){
wheelPower=255;
