IRremote error
I am using IRRemote library but still getting this error:
C:\Users\haase\Documents\Arduino\libraries\IRremote\IRremote.cpp:28:27: fatal error: avr/interrupt.h: No such file or directory
#include <avr/interrupt.h>
compilation terminated.
exit status 1
Error compiling for board WeMos D1 R1.
file interrupt.h exists in instalation folder but IRremote library probably can not find it.
Can anybody help me?
Thank you
Where is the interrupt.h file located
The WeMos does not have an AVR chip. You should use the ESP8266 IRRemote library here
@UKHeliBob interrupt.h is under C:\Program Files(x86)\Arduino\hardware\tools\avr\avr\include\avr\interrupt.h
@blh64 actually my code is older and using older library IRrecv that is not available anymore but probably is now covered by IRremote library. (it worked well but now I need to reinstall one arduino from new PC and I cannot get the old library anymore)
I tried to used IRremoteESP8266 instead but now I got another errors:
_2-IR_obrazy5:20:1: error: 'IRrecv' does not name a type
IRrecv irrecv(sensor);
_2-IR_obrazy5:21:1: error: 'decode_results' does not name a type
decode_results results;
C:\Users\haase\Dropbox\brainteaselava_materialyJanosik\ArduinoRaspberry_2-IR_obrazy5_2-IR_obrazy5.ino: In function 'void setup()':
_2-IR_obrazy5:59:3: error: 'irrecv' was not declared in this scope
irrecv.enableIRIn(); // Start the receiver
Maybe look at the examples that come with ESP8266 library. I don't have it but I'm guessing they may have different function names.
