IRremote.h caussing issues with AFMotor.h
Hi, When I include irrecv.enableIRIn(); in my setup, motor 1 and 2 stops working.
when I comment it, the motor works as usual. any work around to make all 4 motors work?
My plan is to use a remote to send signals to my robot to move in different directions.
My code :
#include <IRremote.h>
#include <AFMotor.h>
int RECV_PIN = A3;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long previousCommand = 0; // To store the previous valid command
// Define the motor shield object
AF_DCMotor motor1(1); // Motor 1
AF_DCMotor motor2(2); // Motor 2
AF_DCMotor motor3(3); // Motor 3
AF_DCMotor motor4(4); // Motor 4
  motor1.setSpeed(255);
  motor2.setSpeed(255);
  motor3.setSpeed(255);
  motor4.setSpeed(255);
  //test();
  irrecv.enableIRIn(); // Start the receiver
  //test();
  if (irrecv.decode(&results)) {
    Serial.print("Received IR signal: 0x");
    Serial.println(results.value, HEX);
    if (results.value == 0xFF48B7) {
      Serial.println("fwd");
      previousCommand = results.value;
      moveForward();
    } else if (results.value == 0xFF7887) {
      Serial.println("bck");
      moveBackward();
    } else if (results.value == 0xFF02FD) {
      Serial.println("lft");
      turnLeft();
     } else if (results.value == 0xFF32CD) {
      Serial.println("stp");
      stopMotors();
    } else if (results.value == 0xFF20DF) {
      Serial.println("rgt");
      turnRight();
    } else if (results.value == 0xFFFFFFFF && previousCommand != 0) {
      // Continue the previous task
      if (previousCommand == 0xFF48B7) {
        Serial.println("fwd (continue)");
      } else if (previousCommand == 0xFF7887) {
        Serial.println("bck (continue)");
        moveBackward();
      } else if (previousCommand == 0xFF02FD) {
        Serial.println("lft (continue)");
        turnLeft();
      } else if (previousCommand == 0xFF32CD) {
        Serial.println("stp (continue)");
        stopMotors();
      } else if (previousCommand == 0xFF20DF) {
        Serial.println("rgt (continue)");
        turnRight();
    irrecv.resume(); // Receive the next value
void moveForward() {
  //unsigned long startTime = millis(); // Record the start time
  motor1.run(FORWARD);
  motor2.run(FORWARD);
  motor3.run(FORWARD);
  motor4.run(FORWARD);
  Serial.println("running");
void moveBackward() {
 // unsigned long startTime = millis(); // Record the start time
  motor1.run(BACKWARD);
  motor2.run(BACKWARD);
  motor3.run(BACKWARD);
  motor4.run(BACKWARD);
void turnRight() {
void turnLeft() {
void stopMotors() {
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  motor3.run(RELEASE);
  motor4.run(RELEASE);
  Serial.println("stopped");
void test(){
  testMotor(motor1, "Motor 1");
  delay(500); // Wait for 2 seconds before testing the next motor
  testMotor(motor2, "Motor 2");
  testMotor(motor3, "Motor 3");
  testMotor(motor4, "Motor 4");
void testMotor(AF_DCMotor &motor, const char *motorName) {
  Serial.print("Testing ");
  Serial.println(motorName);
  // Run the motor forward for 2 seconds
  motor.run(FORWARD);
  delay(2000);
  // Stop the motor for 1 second
  motor.run(RELEASE);
  // Run the motor backward for 2 seconds
  motor.run(BACKWARD);
  delay(2000);
  motor.run(RELEASE);
The IRremote library and the AFMotor library are both trying to use the same timers. That won't work. I'd suggest using a more modern motor shield that generates its own PWM signals rather than depending on the Arduino to do it.
