Hello. I tried to blink with led, when power button is pressed.
this is my code:
#include <IRremote.h>
int RECV_PIN = 11;
char cmd;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
void blinkled(int ledpin) {
pinMode(ledpin,OUTPUT);
digitalWrite(ledpin,HIGH);
delay(100);
digitalWrite(ledpin,LOW);
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
if (results.value=="FFFFFF") {
switch (cmd) {
case "pwr": blinkled(13);break;
else {
switch (results.value) {
case "FF629D": cmd="pwr";break;
this is error:
IR.cpp: In function 'void loop()':
IR:24: error: ISO C++ forbids comparison between pointer and integer
IR:26: error: case label does not reduce to an integer constant
IR:31: error: case label does not reduce to an integer constant
IR:31: error: invalid conversion from 'const char*' to 'char'
Why is it not working?? Thank you for your time.
