IRremote IRsendRawDemo send code but can't recieved the same
I’m recently working on a home automation project.one of the important part is learn and store IR codes and re-send them as needed,e.g impl a thermostat or something.
my IR circuit diagram(see in attachment)
action taken:
1.record a code(power on) from fan remote controller by using IRrecvDumpV2 demo ,
unsigned int rawData[23] = {1250,400, 1250,450, 350,1300, 1200,450, 1200,450, 400,1250, 400,1250, 400,1300, 350,1300, 400,1250, 1200,450, 400}; // UNKNOWN 143226DB
2.send the rawData;
code:
#include <IRremote.h>
IRsend irsend;
int khz = 38; // 38kHz carrier frequency
unsigned int irSignal[23] = {1250,450, 1200,450, 350,1300, 1200,450, 1200,450, 400,1250, 400,1300, 350,1300, 350,1300, 400,1250, 1200,450, 400}; // UNKNOWN 143226DB
irsend.sendRaw(irSignal, 23, khz); //Note the approach used to automatically calculate the size of the array.
delay(2000); //In this example, the signal will be repeated every 5 seconds, approximately.
3.from camera,I can see the light from the IR LED,pretty strong,just look the same from fan’s remote controller.
4.try to aim IR LED at fan,nothing happened…
I think that signal from my arduino drive IR LED were not correct,I don’t know which part went wrong ,my goal is implement a universal remote controller, receive IR signal,store it(without decode),and plays it back,I worked on it for couple of days without any success, pls help me out, or some guides to impl a universal remote controller will helpful,thank you!
If you have it hooked up like your picture it will never flash the led.
be80be:
you’re right,the polarity of LED was wrong in this picture,I connect it in the right way actually(as mentioned,
I can see lights by camera from the LED when sending data),thank you!
