For a class we are getting our Arduinos to 'Multi-Task' and I wanted to include the IRremote library in it. I think I have it typed right, and before you ask, yes I fixed the Timer error between pitches.h and IRremote.h. Apologies, it's sort of long.
#include "pitches.h"
#include <IRremote.h>
//Skipped two classes
class IR
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN); //This line is causing the error
decode_results results;
public:
IR()
irrecv.enableIRIn();
irrecv.blink13(true);
void Update()
if (irrecv.decode(&results)){
Serial.println(results.value, HEX);
irrecv.resume();
Flasher led1(12, 100, 400);
IR IRled1(7);
Speaker
led1.Update();
IRled1.Update();
Hello,
If I download the library from this link below and compile the IRrecvDemo sample, no errors occur.
I can not test your code, files are missing:
pitches.h: No such file or directory
IRrecvDemo:
* IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
int RECV_PIN = 11;
// In case the interrupt driver crashes on setup, give a clue
// to the user what's going on.
Serial.println("Enabling IRin");
irrecv.enableIRIn(); // Start the receiver
Serial.println("Enabled IRin");
if (irrecv.decode(&results)) {
irrecv.resume(); // Receive the next value
delay(100);
Pitches.h don't matter. It had to do with one of the skipped classes. Yes, the demo works for me too, but that's the weird thing. It just won't work in my code. Even though the demo works, my code doesn't. I could post the full .ino and .h files if that helps
